Astra 2F at 28.2E: General Discussion
mickwig
90cm Astra1 dish;
;)Its also a hotspot on the UK beam!!!
Bengt
1,8m PF dish (situated on balcony),Invacom Quad or Inverto LNB (it varies), Sky Digibox, Humax Foxsat HD receiver, TBS8922 card.
Trelleborg (swedish south coast)
Hi
What I don't understand is the 2G Euro beam. The 2F AND 2E Eurobeams are similar, but the 2G Eurobeam is totally different. It is the only (european) beam on 2E/2F/2G which isn't centered on the UK.
Maybe 2E/2F are meant to be permanently placed at 28,2E, whilst 2G will be available to move to provide backup at other locations, should the need arise.
Or it may have something to do with the data transponders; I've seen claims that 11464H AND 11479V are on the 1N PE2 beam. The only beam on the new satellites that comes close to that kind of coverage is the 2G Eurobeam.
Speculation, speculation...
Regards,
Bengt
Retired Mod
www.timo.me.uk
I've always suspected that 2G will be the new "2C" which is used as a temporary satellite at various locations when needed.
The 2G Euro beam doesn't look like it'll be of use in the northern and western parts of the UK and Ireland, which was one of the selling points of the new 2F and 2E satellites (zone 1 dishes for the whole UK).
Hmm, hadn't thought of that. Would love to know what those data transponders actually are...
Luxlizard
150 cm dish >freesat humax foxsat hd+ I use daily
An old sky.uk pace digibox I use sometimes to watch non-freesat channels
90 cm dish >Pace hd for My Sky Italy
humax combo 9000 (terrestrial and sat)
Bologna-Italy
Something has changed ,since last week I can Watch here in Bologna ,Italy,all the various CH 5 and, a little scrambled ,CH 4 HD,....all day.... 150 cm dish..
S
Steve Steve
Yep......40% up here too......Isn't the "UK Spot beam" ...great...??...It's just causing unnecessary expense & general unpleasantness for all expats/UK TV sat installers ...and Foreign uk tv fans...!!!!
4wd
Getting the picture
5 W, 9-13-19-28 E
Still much better 2f 10964 (ch5) here. A little larger dish\some adjustments I'd get stable 24\24 reception. Previously signal went to zero for long periods, now always stays above 30% and even seen it up to 70% for some periods of the day.
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
I think also 2F EuroBeam is now more stable here..
cazhh
Elmshorn, Schleswig-Holstein
Something happened to 12522V, 12552V, 12611V and 12640V at least
This morning this happened on 12522V:
Crazyscan shows that the 4 vertical transponders have changed probably to one of the spot beams:
Do you see that as well ?
Edit:
The snr values are
12522: 7.7db
12552V: 12.0db
12611V: 11.1db
12640V: 7.7db
I would guess the first and the last one are on 2F spot, the others on 2E spot
cazhh
On the other hand, the reduction of the SNR took almost a hour to complete.
140429 06:31 UTC 16.4414
140429 06:32 UTC 16.4805
140429 06:33 UTC 16.3984
140429 06:34 UTC 16.2617
140429 06:35 UTC 16.2539
140429 06:36 UTC 16.1602
140429 06:37 UTC 16.2031
140429 06:39 UTC 16.0234
140429 06:40 UTC 16
140429 06:41 UTC 15.832
140429 06:42 UTC 15.8086
140429 06:43 UTC 15.6367
140429 06:44 UTC 15.5625
140429 06:45 UTC 15.4141
140429 06:46 UTC 15.1445
140429 06:47 UTC 15.1289
140429 06:48 UTC 15.168
140429 06:49 UTC 15.1328
140429 06:50 UTC 15.1133
140429 06:51 UTC 15.1055
140429 06:52 UTC 14.9531
140429 06:53 UTC 14.6172
140429 06:54 UTC 14.25
140429 06:55 UTC 14.207
140429 06:56 UTC 14.0664
140429 06:57 UTC 13.9414
140429 06:58 UTC 13.8906
140429 06:59 UTC 13.7656
140429 07:00 UTC 13.707
140429 07:01 UTC 13.4492
140429 07:02 UTC 13.3281
140429 07:03 UTC 13.293
140429 07:04 UTC 13.1992
140429 07:05 UTC 12.9648
140429 07:06 UTC 12.8945
140429 07:07 UTC 12.5195
140429 07:08 UTC 11.6016
140429 07:09 UTC 11.7656
140429 07:10 UTC 11.2852
140429 07:11 UTC 11.2266
140429 07:12 UTC 11.125
140429 07:13 UTC 10.9531
140429 07:14 UTC 10.668
140429 07:15 UTC 10.2891
140429 07:16 UTC 10.0742
140429 07:17 UTC 9.75391
140429 07:18 UTC 8.88281
140429 07:19 UTC 8.79297
140429 07:20 UTC 8.75
140429 07:21 UTC 8.73047
That would't happen if they just switched the beams. WTF ?
Retired Mod
www.timo.me.uk
Signal levels here in the UK look the same as they did a few months ago. If something would have switched beams I've have expected quality to vary a little at least but it is hard to tell here as they are all quite powerful. Are you sure it's not local interference or issues?
cazhh
No, i'm not. What irritates me is that it's just those 4 transponders which have changed. all others in that band are normal.
I haven't read about a failure in a LNB which would have just a few transponders to fail. But who knows.
Retired Mod
www.timo.me.uk
It's certainly odd. We need someone else outside the UK can check these levels... Anyone?
cazhh
19.2 is not affected. So either it's the LNB or something is transmitting right into my dish at 28.2. Or something with 2F. In south germany this is not visible.
I will switch the LNB tomorrow morning.
tothbros
Budapest, Hungary
reception of all the mentioned frequencies are unchanged at my location. i have zero reception of spot beams, so i would have noticed :)
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
12522V: same
12552V: same
12611V: same
12640V: same
all same as before.
FRINGE
Adeje in Tenerife
laminas 2.7 offset
laminas feed horn
Invacom quad LNB
Humax foxsat PVR
Tenerife
Signals for those transponders are still very strong here so definitely not on a spot beam.
cazhh
It was the LNB. It's weird that just a few frequencies fail and not the whole band. :mad:
Retired Mod
www.timo.me.uk
If you think that's weird, I've got an LNB that is repeating a few transponders on nearby frequencies and blocking out the real transponders. Confused the hell out of me for a while.
popolon
south west of Finland
Teleste 5m,invacom quad (28.2E), invacom quattro (26.0E). Triax multiswitch (1in, 8 out)
-TT 1600 PCI. Prof 3701 PCI.
-DR HD F15
-Ariva ferguson A120
Aerial 3m dish (7W-28.5E) + motor+ invacom quad.
-Ariva ferguson A220.
Finland
What has changed to 2F orbit slot movement, as the center of box data does not anymore show two time periods for day, but only very long period (from start to stop) ? Is it still moving as 8 ?
