You've asked this several times now and the answer is still the same. I fitted LH110 dishes throughout the Costa Blanca between Sept 2012 and Feb 2014. Not had any complaint yet about one not working since 2E came online, but the signal is marginal in the south Costa Blanca. If you want to see data from the LH110
have a look here. That has been collecting data from an LH110 in Alicante every 10 minutes on every transponder ever since February 18th. In Javea signal is probably about 0.5-1.0dB stronger. But personally if the install was for me I would use a 1.4m offset dish just to have a little bit extra in reserve. BTW, in the table linked above channels are always watchable as long as transponder data doesn't say 0.00. And 8.00dB is very close to the limit for the 8PSK transponder reception limit.
