Crankshaft vibration pulley damper
Archived-1
Persona non grata
uk
The above went on my old Peugeot Friday, at first I thought it was the bottom end:eek:, it turns out to be an easy fix and the hardest part is working out were the alternator belt runs,
Half hour work and back on the road :), break pads and discs next job:).
Which engine was that from? It looks very similar to one I changed.
I changed the pulley on the Xsara (HDi engine) four years ago. We had been on a short touring holiday within a holiday in August starting and finishing in France. We went through Andorra, down Spain to Gibraltar and back in seven days.
I had noticed a slight noise when coming back through Andorra but by the time we got to Montpellier it quite noticeable. The noise went away (!) when I turned the A/C off so we continued slowly on using ordinary roads. Unfortunately by the time we got to Nimes even that didn't work We took the final forty five miles quite gently indeed.
Back at base we were joined by some friends who were able to run me into Orange where I was able to buy a new pulley. Prices of car spares in France are much greater than in the UK and it was nearly twice what I would have paid normally.
However, needs must. Back at home I went to work on the grass surface and in a surprisingly short time had changed the pulley. My friends were very impressed as they imbibed wine at the outside table as I worked!
Yeah these dual mass pulleys tend to fall apart very quickly from the initial noise. Easy to replace though...
Archived-1
Persona non grata
uk
Yes Paul, HDi engine, only last week my next door neighbours went, he has a Citroen van same part number as my old 206.
Piltdownpaul
No.1 Spike Milligan Fan
Goes on the 1.4,1.6 diesels, done so many of them i've lost count. Down in Leicesterland there lots of those french diesels around especially as they go in the fords now.
Archived-1
Persona non grata
uk
I did not realise one thing when I bought the part, if the belt breaks, it will damage the new part, I will go and get a new belt tomorrow, that's trying to save a few £:-dohyou could in the older days:).
Piltdownpaul
We dont change the belt Martin unless it looks visually damaged.
