Difference between H-H and polar mount
Discussion in 'DISH SETUP: Single sat, Multi-Sat & Motorised' started by kamaleon, Jun 24, 2006.
  1. kamaleon
    kamaleon Regular Member
    Dec 2, 2005
    818
    My Satellite Setup:
    skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
    My Location:
    str8 frum da wesside innit?
    Hi folks...
    Say, please, what is the *main* difference between a horizon-to-horizon mount and a polar mount? Is there one? or is this just a way of referring to the different kind of motors? I mean, a declination is a declination, a polar axis is a polar axis, innit? can they be different in one or another way?
    Sorry if this is a dumb question, but i don't seem to find any "idiot's guide to the differences between H-H and polar mounts" :D
  2. Topper
    Topper Amo Amas Amant Admin Staff Member
    Nov 18, 2004
    17,453
    607
    My Satellite Setup:
    IDD CI24 ECONO MM Penta 1.20 Galaxy II
    1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
    My Location:
    Blackburn, Lancashire
    A polar mount is engineered to describe the Clarke curve in the sky and will do so once set up correctly with or without a motor. In other words (once set up) you could have a pulley system to move from one sat to another, you can swing it by hand and it will still track the arc. An H to H mount is a lot lighter and works in a completely different way
    Below is my Polar mount
  3. kamaleon
    Dec 2, 2005
    818
    My Satellite Setup:
    My Location:
    Ah!!! Just when you got me started, then you left me hangin...
    :D please, by all means, do further explain, if you may :D
    which completely different way is that? ;)
  4. Lancelot
    Lancelot Specialist Contributor
    Jun 1, 2004
    3,636
    36
    My Satellite Setup:
    SS1.
    36v H to H 62E - 61.5W
    My Location:
    Here again
  5. johnsattuk
    johnsattuk Oldgeezer
    Sep 4, 2004
    433
    2
    My Satellite Setup:
    Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
    My Location:
    West Mids, UK
    I have myself pondered on the differences between 'Polar' & 'HH', and could essentialy see none.
    To track the Clarke belt you need to,
    (1) rotate the dish about an inclined axis
    (2) give the right amount of declination to the dish
    (3) point it south at the top of the arc
    Topper's wonderfully simple setup has an inclined axis, a way of adjusting the declination, and a means of moving it. Just like any HH mount. The differences being in the different engineering design features to get to the same end result.
    I don't find my Yaeger 1224 HH mount particularly light when I am up the ladder :D
    On further reflection, I would suggest that any tracking mount, that is aligned to the 'polar axis', ie: north/south, is by definition a 'Polar Mount'
  6. kamaleon
    Dec 2, 2005
    818
    My Satellite Setup:
    My Location:
    Spot on Old geezer, exactly what me thought too...
    A polar axis is a polar axis, whether it be "driven" by a diseqc motor or an attenuator... am I wrong?
    I still wonder what Topper ment by "a completely different way"... ?
    On this link:
    _http://www.satsig.net/polar-mount-4.htm
    they clearly refer to the moteck sg2100 as a polar mount :confused
  7. Lancelot
    Jun 1, 2004
    3,636
    36
    My Satellite Setup:
    SS1.
    My Location:
    Here again
    An attenuator really IS something different. :D
    You mean a jack I think.
    L.:)
  8. johnsattuk
    Sep 4, 2004
    433
    2
    My Satellite Setup:
    My Location:
    West Mids, UK
    Or even an 'Actuator' :)
  9. Topper
    Nov 18, 2004
    17,453
    607
    My Satellite Setup:
    My Location:
    If you analyse the forces involved when the wind blows the dish the 'feedback' to the motor has a completely different path making the actuator method of moving the dish far stronger than the alternative H - H motor. That is what I meant, if you remove the motor on an H- H mount the dish falls on the floor and cannot track the arc if you disconnect the motor on my polar mount it can still track the arc whether by hand or strings. It is a totally mechanical tracking device driven by an electric motor or other. The H - H mount does not do anything without a motor hence my statement completely different.
  10. johnsattuk
    Sep 4, 2004
    433
    2
    My Satellite Setup:
    My Location:
    West Mids, UK
    Wind is probably the greatest force on the dish, and is often the cause of the demise, but because of the inclined axis, the dish itself exerts a force on the drive system when off centre, and this needs to be added/subtracted to the total loading. Gregorian dishes with a second reflector outboard giving an even heavier loading.
    The feedback to the driving system is torque, how you resist that torque is a matter of design.
    A linear actuator driving a dish, through a lever, may well be stronger than a Motec 2100, which only has a smallish plastic gear to resist the torque.
    I have however seen a faily substantial actuator coupled to a dish via a flimsy lever which would fail long before the actuator did.
    A Yeager 1224 HH motor has a substantial steel gear and worm, for which you pay.
    The linear actuator no doubt will give the strongest solution from a cost point of view.
    I don't see them as being different, just different design concepts and solutions to give the same end result. :D
  11. Topper
    Nov 18, 2004
    17,453
    607
    My Satellite Setup:
    My Location:
    Yes exactly the end result being one snaps the teeth of the nylon crown wheel in strong winds, the other doesn't O-Ha O-Ha O-Ha
  12. PaulR
    PaulR Dazed and Confused Mod Staff Member
    Jun 28, 2003
    10,378
    368
    My Satellite Setup:
    Various digiboxes, broken Nokia 9800S, numerous analogue boxes. A Foxsat HDR which moves with me between the UK and France. Main TV: UK Philips 42PFL9632; France 47PFL9632
    My lovely little lappy, Toshiba Satellite Pro L20
    My Location:
    Wirral, NW England; Vaucluse 84, SE France
    I think that the essential difference is that an H-H mount is directly driven off a gear and a polar mount has an actuator arm pushing the dish.
    This difference is important in traditional motor drives where the H-H motor has a fixed number of pulses per degree moved and, because the actuator is pushing at a tangent, the number of pulses increases (or decreases - can't remember) as you move from maximum to minimum.
    As Topper says, the biggest problem with H-H motors is broken gear teeth after high winds.
  13. johnsattuk
    Sep 4, 2004
    433
    2
    My Satellite Setup:
    My Location:
    West Mids, UK
    _http://www.satsig.net/polar-mount-4.htm :confused
  14. Channel Hopper
    Channel Hopper Suffering fools just so you don't have to Staff Member
    16,724
    570
    My Satellite Setup:
    My Location:
    UK South East
    Almost, the price of a decent polarmount system (including actuator drive)is usually far less than an Horizon to Horizon mount with similar accuracy.
    H-H mounts do become far cheaper to manufacture when you are only dealing with 1m antennas, average weather, and dubious online guarantees. But they are almost unique in having the ability to move dishes using the LNB drive circuit and DiSEqC protocol.
  15. johnsattuk
    Sep 4, 2004
    433
    2
    My Satellite Setup:
    My Location:
    West Mids, UK
    I'm sure cost is one of the biggest factors, if a manufacturer thought that enough people would pay a high enough price, we would have very robust Diseqc HH mounts. There are no technical or engineering difficulties.
    There are also some Diseqc actuators appearing, best of both perhaps :D
    Topper's mount with a Diseqc linear actuator, the ultimate :cool:
  16. kamaleon
    Dec 2, 2005
    818
    My Satellite Setup:
    My Location:
    Jeezus, how many posts since me went to bed yesterday!:eek:
    Yes, i actually ment a jack/actuator :-doh2
    i'll read the rest of it now :)
    edit: ok have read :D
    Right on fellas,
    So, basically, to sum up, technically speaking, a H-H mount tracks the Clarke belt using the same type of declinations/elevations than a polar mount, and a polar mount is a more full-on setup being able to cope with higher loads, heavier dishes and stronger winds;
    I'm sorry if this sounds stupid, but the reason for my thread on the first place was that i didn't understand the difference between the way the 2 different mounts tracked the clarke belt, but i've now realised: it's exactly the same :D
    Actually, thinkin of it, "polar mount" vs "horizon-to-horizon" seems like a quite daft designation, as both setups seem to be polar mounted (ie used the polar axis) and track one horizon to the other - or is the jack/actuator system more limited in ° scope?
  17. kamaleon
    Dec 2, 2005
    818
    My Satellite Setup:
    My Location:
    Are you talkin' about let's say a Vbox positioner?
  18. Lancelot
    Jun 1, 2004
    3,636
    36
    My Satellite Setup:
    SS1.
    My Location:
    Here again
    I think what he's saying is that there are/wiil be, jacks/actuators that are diseqc controlled like the SG2100 et al. As opposed to the current crop which are 36V controlled and require a VBox to run them on most modern recievers.
    L.:)
  19. johnsattuk
    Sep 4, 2004
    433
    2
    My Satellite Setup:
    My Location:
    West Mids, UK
    I do have a SuperJack DiseqC 1.2 actuator that I was going to play with, but went a different route. It works directly off the reciever, no V-Box required. :D
    SuperJack DiSEqC 1.2 actuator, 12v motor 8inch stroke. DARL-1208+
  20. Channel Hopper
    16,724
    570
    My Satellite Setup:
    My Location:
    UK South East
    Unless the actuator is matched perfectly to the polarmount, there will be a limitation on one (or both sides ) of true South.
    One problem of standard polarmount designs on walls is that the actuator will stick out the back of the system, and may run into the wall if the bracketry is too small.
    Many of the cheaper polarmount designs also restrict the distance of the actuator from the main point of rotation and then accuracy of tracking and positioning is affected, and leads to premature wear of all parts.
    I would be very wary of any polarmount that can only use the mini jacks, though I do have one prototype in the garage somewhere that did look the business - will try to get some photos later.
Share This Page
Click here to support our sponsors
