Help Required DM500HD eSATA HDD problem
zafir.kamberski
DM500HD with OpenPLi 2.1 image
Macedonia
Hello everybody,
I recently bought Fantec DB-ALU3e 1TB external hdd with eSata and USB
ports. I tried formatting it in NTFS format but the DM doesn't recognize
it (I previously used CoolerMaster hdd box with 1.5TB sata WD hdd in
it, also in NTFS format and it was working fine).
My DM is using the OpenPLi 2.1 image.
I tried initializing/formatting directly from the DM in Ext3 format and
also the same thing from PC with Mini Tool Partition Wizard and mounting
it on Win7 with Ext2 Volume Manager. The format went ok, I copied some
movies (mkv format) on it, connected via eSata onto DM, it now
recognizes it, plays the movie for about 30 sec or 1 min and blocks,
stops the movie and again it doesn't recognize the hdd. When I turn off
and again on the hdd it happens the same... It happens the same also in
Ext4 format.
I tried also in FAT format and it doesn't recognize it.
Please help, I'm desperate
How is the external drive powered? If its usb powered you might find the DB cant supply enough electric power to run it.
zafir.kamberski
Macedonia
It has it's own power supply.
Swap the drives over & put the original one back in?
zafir.kamberski
Macedonia
It works perfectly on NTFS
