Do i need a motor, astra, hotbird, arabsat
ali abboud
dont know what this is ?
London
i already have a satellite dish with 2lnbs one for Hotbird and one for Arabsat and they both work fine.
I would like to fit another lnb for sky (astra 28.2).
Would i need a motor for this or no?
Also does anybody know where i could get one of these lnb holders that fit inbetween a metal line for the lnbs bolts going down ?
satelliteman
Astra28e and 26e are too close for an lnb offset arrangement. A motorised system would be advisable with at least a 1m dish.
ali abboud
London
what is a lnb offset arrangement exactly?
ali abboud
London
what is a lnb offset arrangement exactly ?
satelliteman
LNB offset arrangement; referring to LNB's placed on an offset bracket.
bambule666
3.1m-primefocus,2.9m-offset,2.4m- chanelmaster, 1.2m chanelmaster, Invacom and inverto lnbs
Tenerife sur
Hi , if you use a 1.2meter dish u can put on central 26arabsat, and left and right astra19 and28, but need to use rocket feef. I did it many times , work good!.how bigger is the dish more distance is between the LNBs ! 1 meter or smaler i not posible for arabsat and astra28.
On 1.35m Works as well hotbird 13 , but than chose astra 19 for central LNB
