- May 29, 2009
- North York Moors
Well clearly something is wrong as you are within the 48dBW contour so a 120cm dish is massive overkill (Assuming it's aligned to 5W and not elsewhere ie part of a multi-LNB system).
You should have enough rain-margin to stave off even extreme weather: So much margin that a deaf receiver shouldn't present a problem either.
Although I've never experienced it myself, despite occasionally using a 1.1m on 28E, there are occasionally reports of overloading causing problems. Indeed, I believe such an issue is mentioned on the Costa Blanca 2E/2F Thread
