bella
- Jun 26, 2008
- Age
- 36
- FTA Satellite TV
- Australia
I purchased a second hand Topfield 3200IR. I tried it on my existing system, which is working fine, it gave me an error message " E48 no signal" I took the receiver to my friends house who has a similar working system and tried it. I got again the same error sign. Is the STB bad? not working? or is there anything I am missing in the installasion of the STB. The manual does not refer to any error as such. What is the problem? How can I fix it? My system has two separate dishes one Ku ( small ) and the other is a C-Band ( 2.3 mtrs. Large) which I installed recently. I have a satellite finder meter. inclinator, compass and an azimuth wide scale pattern to fit aound the 76.1mm pole ( 3.00 inches). I am getting a good reading on the satellite finder but no quality reading on the topfield receiver. Lnbf level reading goes to 78%
They are not interconnected with a DiSEqc switch . I am using them individually to two different areas in the house.
I need your expertise.
Regards .
Regards .
