Fibo 1.2m v Channel master 1.2m
Riverblue
Near Brighton
Riverblue
Near Brighton
From what I can see given two dishes of the same size, one an offset type the other gregorian, both at the same location and in perfect condition, with lnbs of the same performance and set up correctly with the right equipment, then the gregorian should provide slightly better results. But I can't see any factual information to back up claims that a gregorian dish will equal or outperform an equally well set up quality offset dish of a substantially larger size, which was the claim (by another) that lead to my discussion initially and seems (to me) to be somewhat of an urban myth not backed up by fact IMHO. But I'm happy to be proved wrong because I am by no means an "expert" :)
BlindFaith
TBS 5925
BlindFaith
TBS 5925
nope, but read this again :)
the real advantage is that the secondary reflector may be used to reshape the illumination of the reflector for better performance.
Riverblue
Near Brighton
Yep, read it, again!;) Okay, offset v offset gregorian, but you knew what I meant, we are just quibbling over semantics.
I still refer to my post #22, I agreed that the "offset gregorian" should perform better than a similar sized/installed/quality "offset" dish.
But, I have still to see or read anything to back up this "urban myth" that a "gregorian offset" performs way beyond it's size! In post #16 CJ states that the Fibo was slightly better than the Channel Master but was "walked all over by his 1.5m Gibby",:eek: that suggests to me that it's performance wasn't even close! That hardly backs up the statement that "my Fibo performs like a 1.8m dish" by "another" Maybe a poorly installed one.:D
BlindFaith
TBS 5925
My 120cm Echostar is in fact a channel master. It's in place since more than 20 years and survived a couple of storms. The arkivator actuator (optocoupler) is still working very precisely. Only the LNB(F) has been replaced. The 1st was an expensive Chaparral wideband lnb ;) The mount was controlled by an Echostar SR8700 positioner that was replaced after the power unit failed by a LT8700 with RS232 interface. No USALS or similar crap ;)
I don't think that a FIBO type would have lasted that long :D
Riverblue
Near Brighton
That's what I like about Channel Masters (and the like), they are bloody solid and nigh on unbreakable :D and they do the job!
Yes I am not sure what I prefer. The tough CM or the not as thought but slightly better performing/looking Fibo.
No, I do know. The 1.8m CM :D
Riverblue
Near Brighton
If only :confused. . . maybe if I :confused. . . . . . No stop:eek: . . . . NO MORE :(
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
You are right. My Fibo hasn't lasted 20 years... but close at 19 years, although the dish face itself was replaced within 1st year after some vandals decided to throw rocks at it. There is now a fence around the garden and it is safer now our neighbour dumped her "boyfriend"!
Riverblue
Near Brighton
Wow, 19 years, that's good going, sounds pretty robust to me. Is it still on the original motor, assuming it's motorised.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
The original motor used an optic sensor with a 5 volt supply. I swapped it for a reed guided modified original motor when the optic sensor failed. The dish had replaced a channel master 1.2m when I wanted to have a higher gain dish without the impact and expense of a larger dish.
Trust
Nijmegen Netherlands
@Trust1, IMHO it's not that easy to compare the dishes. A gregorian dish normally comes with a matched feedhorn which could give an additional advantage compared to a standard offset-LNBF.
The Fibo has still his original feedhorn , to it a modded BU single at the time of that test .
@ Rimants , believe me , my 120 is not warped , the extra rods at the back keeps it in shape .
RimaNTSS
Some SAT-related hardware.
N-E from Riga
@Trust1 that is why I've said
it is not so easy to find Fibo in ideal shape
That means it is still possible to find not warped dishes :rolleyes:
I doubt you did not checked and corrected shape of your antenna (antennas). Dishes I checked for warpage (especially 90cm) all out of ideal shape. And, THB, I am afraid to string my Fibo120.:mad:
Riverblue
Near Brighton
So you've had both dishes, can you dispel/back up the "urban myth" about the phenomenal performance of the Fibo, in your experience did the Fibo massively outperform the Channel Master (assuming it was a 1.2m!) or were the differences a lot smaller? :)
