Just placed an order for a couple of these 'flanged bearings' ...
http://www.ebay.co.uk/itm/400490300918?ru=http://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_nkw=400490300918&_rdc=1
at the price I'm not too worried if I can't use them ..
But am hoping they might be fitted by drilling out the cast ally holes on the motor mount ...inserted with the flanges to the inside ....and secured with M10 stainless Nylock nuts applying pressure to each flange ...having replaced the M10 nuts n bolts with a single 6 inch stainless steel 1cm threaded bar running right through side to side..
Hope you can visualise this ..
More to the point ...I hope it's feasible .
My main worry will be drilling out the ally hinge points under the motor case ..and although it's about 1cm thick ...might weaken it somewhat.
The yellow unmarked spacers would be washers made from Teflon...
The whole dish will have to be disassembled and the motor removed for this one.
Not a job I relish much...so maybe it might not get done this year.
We shall see.
rgds
VS
(rough sketch and not to scale just to give an idea of my plan)
Thinking out loud so to speak..
