How to calculate Elevation angle for Offset Dish ?
al_madhi
Riyadh - Saudi Arabia
Hi,ppl I find it too diffecult to calculate the elevation angle for offset dish while with the prime focus dish it is very easy to calculate the elevation angle Is there a technical formula to convert elevation angle from prime foucus dish to offset dish ?
Best Regards
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Can you catch some satellite with that dish? If yes than get maximum signal by changing elevation and than measure elevation angle of antenna. So, you know elevation of that particular satellite for your place, extract from that your measured angle and that will be antenna's offset angle.
Archived-1
Persona non grata
uk
in the end the link below helped me to set mine up, hope it can you.
hxxp://www.satsig.net/polmount.htm
al_madhi
Thanks Sleepy Hollow for your help regarding your question yes I receive this satellite Turksat 2A at 42 E with the prime foucus dish the elevation angle 60 degree But with the offset dish not easy to get the elevation angle because the offset dish is almost upright tilt to the horizontal level only a few degrees and not easy to get the elevation angle to receive the satellite signal but knowing the a fixed angle save time and a lot of work trying to adjust the dish to get the wright angle
BlindFaith
TBS 5925
You need the offset angle from the manufacturer.
Archived-1
Persona non grata
uk
thats what i thought but all suggestions were around 10 degrees out, study the link ive posted and it will make sense, (after a day or so)
Archived-1
Persona non grata
uk
also take a look here
hxxp://www.wotsat.com/news/article/installing-a-36v-motorised-dish/9704
and here
hxxp://magnetic-declination.com/
RimaNTSS
N-E from Riga
You are right, but, there is no way how to calculate offset angle of the dish. If you know exact model of your antenna than you could find that angle in manual. You also can try to post some pictures here and, who knows, perhaps somebody can recognize the model. Is that really so difficult and time consuming to tune that antenna to one satellite? :-doh2
Archived-1
Persona non grata
uk
Finding satellite dish offset angle.
hxxp://www.satsig.net/pointing/finding-dish-offset-angle.htm
Archived-1
Persona non grata
uk
my above post was not meant to prove anyone wrong, i was just trying to be helpful :-thumb1
Piltdownpaul
No.1 Spike Milligan Fan
This is how i did it, once calculated on a known satellite,away you go.
