- Dec 10, 2004
- 1.2M Channel Master, 1224 motor, VU+ Duo 2
- North West
Does this only happen when you're browsing the internet, using Firefox?
Have you noticed if it happens when using flash player?
If you do an internet search, for VPU Recover, you will see many have the same problems, but usually when playing games, but equally this can be due to overheating, you can try taking the case sides off and see if this extra cooling stops the problem.
It could also be down to your memory sticks, try removing one and see if the problem still occurs, if so try removing the other stick and replace the on you previously removed.
How much RAM do you have, and how many sticks of memory?
Are they all the same brand, and type?
