ITV HD settings on various (mainly non Freesat) HD boxes
foseco
80cm and 1m motorised dishes, 30w to 53e. DM500 and DM800. Server running MS Server 2008. Freenas NAS. Custom built desktop PC and 2 x laptops all running Windows 7.
Staffordshire, UK
foseco said:
I'm getting sick and tired of this. I can't get this bloody service added to my DM800. I edited my LameDB with DCC and successfully added a new service ITV HD using the following details...
290E:011A0000:090B:003B:1:0
ITV HD
p:BSkyB,c:000D49,c:030D49,c:040D4A,c:050001,f:5
...but when I view the channel it picks up Disney Cinemagic listings and there is no picture.
I have tried following the instructions here using Dreamboxedit but the new service fails to appear in the channel list.
This is the info that Dreamboxedit adds to LameDB...
290E:011A0000:090B:003B:4:0
ITVHDNew
c:000D49,c:030D49,c:040D4A,p:BSkyB
end
Edited with LlamaWare DreamBoxEdit 3.0.0.0 on 21Nov2009 18:37:25
Can anyone please give me any help, I'm pulling my hair out trying to add it. My image is the latest Gemini.
Foseco
Finally got it added using the following...
0f06:011a0000:090b:003b:134:0
ITV HD
c:000D49,c:030D49,c:040D4A,p:BSkyB,c:050001,f:5
althom40
1.2m dish on Astra 28E . Plus Motorized 850cm .
TM3500D and 6800HD receivers. Freecom 1Tb ext-HDD.
Openbox S10 Redline 3000
Eastern Algarve 37n 08W
wildebed said:
This is a cut/paste from another forum but itapparently works - use the NDF editor and....
a. tune in so you get Brit Shorts etc
b. take a copy of NDF
c. goto transponder 11.428 H
d. Make name ITV HD
e. Set up channel
Service ID: 0x290e
Service Type TV
PMT PID [leave blank]
PCR PID: 0x0d49
Video PID: 0x4d49
Audio PID: 0x0d4a
Check Mark AC3
Lastly and most importantly check the box, "Don't Update Video / Audio PIDs"
f. download to box and enjoy
Haven't been able to do this.
I have a still picture on 11426H. Nothing on 11428H
Tried with the Clarke-Tech Editor but there is no place to enter the
0x0d49 etc. Do I need another editor?
regards
josh2
x
uk
Always good to see my posts ripped off by someone else and put under their name. The instructions above are what I published across the net when I got the CT5000 sorted for ITV HD. Now you can put those commands into the official CT editor that you get off their site or the p one which was / is available off the German "Corner" site.
Saying this for the CT5000 you no longer need this modification since CT changed their software to work with ITV HD. I think from a quick read you were trying to use this method on another box / sister product from the same stable as Clarke Tech. In so far as you can't get the 0x0d49 into the CT Editor you can, you must be using some other editor or old editor.
I trust this helps.
althom40
Hi Josh2. Well the editor i used was the Clarke Tech Editor Studio
v 1.11
It does edit the TM channel lists.
Perhaps I am using the wrong version. I will try to source the correct version. I tried NDFedit but that still did not allow me to enter these 0x values etc
regards
mariuss
VU+ Strong Motor Dish 1.1m with Inverto Black Ultra
Dublin-Ireland
i had same problem whit my tm 6900,but after i manualy input all the pids i scaned frq 11428H27500 and found itvHD in radio list... good luck!
josh2
x
uk
althom40
OK I switched the laptop on where all this is stored....
I used NDFEdit from the CT site [assuming that board rules from elswhere apply concerning no live links]:
http://www.clarketech.altoma.biz/infocenter/downloads?template=detail&entryid=10&lang=en
You just run NDFEdit.exe
My instructions correspond to that software since PIDs are shown up differently in different software, these are in Hex. That lock PID command (check box) out witted the ITV header that forces the box to read it not as a correct HD stream.
The attached word document [screen dump] is what my NDF file looked like at the time viewed via the NDFEdit where I created it. So if you view your parameters and ammend so that ITV HD channels looks like this... it may work if the story of this fix works with your box, it is for the CT5000 as I said further up.
On showing as radio this is where the video PIDs are wrong which is the defacto situation that our BBC Engineers working for Freesat wanted to create by giving it a rubbish header...
  • Doc1.doc
althom40
----------------------------------------------------------------------------Happy New Year Marius and Josh2.
What happened last night was:------
On the 6800HD box I switched to radio channels/advanced search/all channels (previously I searched TV only). /DBV-S and freq 10428H./27500
Search------
This time on the TV side, 10510 came up also Brit Shorts too which wasn't there before.
10510 showed 10426H with 1080i resolution. ITV HD now present on screen.
Renamed and all OK.
Thanks for your assistance guys. All I have to get now on the 6800HD is the EPG for BBC3 and 4. Its OK with my 5300D box off the same dish.
regards
regards
Mostie
AZBox, TM9100S, Vantage X211 usb, H-H mount, Televes 1.1mtr, inverto black ultra.
Central Scotland
working on AZbox, the channel appeared as a long number just renamed it.
mariuss
Dublin-Ireland
but why itvHD is "hiding" it does'n show up on most sat websites and all the hassel to receive it,has to be a reason ...
ITV HD was intended to be exclusive to Freesat, to prevent viewing by Sky HD receivers (power play by ITV). The transmission parameters used could not be resolved owing to the restrictions of the Sky HD box.
We eventually found a way round this by using the methods detailed in this and other threads for the various HD receivers.
Ironically, it's now possible receive ITV HD on Sky HD boxes, even though the ITV site still maintains it's 'exclusive to Freesat'
Well another aspect is that it is transmitting FTA other than on 2D so would have some Rights Issues if it were a mainstream Channel. So, very much like BBCi Sport, it is "hidden" under the Red Button for the time being.
But all that is due to change soon and that has already got underway with the rebranding from ITV HD to ITV1 HD.
As you may be aware, ITV1 HD is due to launch on Freeview and IIRC will also launch on DSAT.
No idea where they are going to stick it, so to speak, though, as I assume it would have to go on 2D.
That said, some Sky owned space was clear recently................
developers
www.development.plus.com
Vu+ Solo 4k PVR using Enigma2, Motorised Triax 1.1m, fixed Orbital 80cm dish with 3 LNB 13e, 19.2e and 28.5e 4/1 way diseqc Cas 3+ Diablo 2.3 & TRex 4.6 Rover SDM2 & Satlook HD
Cheshire.
I've not heard of "IIRC" but look forward to finding out more. But "IIRC" is normally an acronym for "if I recall correctly" - Is this going to be a channell of re reuns?:)
Jem
pajo100
1.2 /1.8 Channel Master fully 36v motorised 58west to 42east Pace MSS500 Positioner
,Technomate 6900 Super HD ,Humax 8100PVR oh and a Amstrad Sky+ digibox.
Ireland
I have had this problem since purchasing the Comag SL100HD about a year ago so got the editor and put in the latest pids but it only gave audio on ITV hd so I did a rescan of the transponder and lo and behold the video appeared so I imagine they have altered something in the stream to allow this.
Anyone with probs should try a rescan now.:D
pajo100
Ireland
Fortecstar1 said:
IF you load the latest software and allow the epg to load on initial reboot you will have access to the full 7 day epg. Press epg button then move to ITV HD in the channel list (channel 110 I think in our preformated list) then select green button ...you can now scroll through days of the week at a glance to determine what is on ITV HD. Usually 9pm most evenings plus footy occassionally and each Saturday for next 3 weeks Star Wars is on.
Is it possible to get the 7 day EPG on other non-freesat models of HD boxes?
Thats all been filled up again by SBO channels :D
Typical.
More dosh for the Murdoch coffers.
GDS 7000 HD receiver - (Basically an HD box for the DigitAlb service but being used for fta channels here)
ITV1 HD works out of the box with absolutely no changes required to the video parameters
(The screengrab isnt HD quality as I screencap it via rf on my computer)
angelheart.gr
Dreambox 500S
Thesaloniki, Greece
Here are instructions on how to receive ITV HD on a Edision Argus mini. The screenshot is from my seteditargus mini.
Some parts are in greek ( I am greek) but I think the picture is more that understandable.
Enjoy
Simos
Lost-in-space
Fortec Star Passion HD+
Kent
danit said:
working perfectly audio & video for me with these parametres
Can you list the parameters in the thread for the Fortec Passion+ HD box, as I can't seem to access the link.
Many thanks
Steve
