NEW Heavy duty H TO H 36 VOLT MOTOR for Pole mounted or channelmaster dish
sonnetpete
wordpress.com
Normandy, France
Yeah I bought one for use with a 1m CM dish. Won't get around to installing it till next year but it looks good
Archived-1
Persona non grata
uk
Thanks all, we will have to see how C/J goes with his,
Costactc
Canada
Just curious, will that motor be strong enough to move my CM 1.2m dish? It would be a bonus as I wouldn't need a polar mount or an actuator.
Archived-1
Persona non grata
uk
Captain Jack would be able to tell you best, but he is on his holidays atm Costactc, unless anyone else can help ?.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Last summer I've opened belly of such a motor (to open was much easier than to close), but did not install it yet. Hoverer, I feel it can hold CM120 without any problems.
Looks very similar to something I have in a box in the back room, (turret and top nut clamping are virtually identical. The motor is on a solid alloy post clamp with locking bolts though, none of this 'U-bolt' and steel plate stuff.
Will try and get a few pictures later.
Costactc
Canada
I received a reply from the seller and he said the CM 1.2m dish can be moved with ease with this motor as he uses it to move heavier steel dishes. I pulled the trigger and ordered one-no need for a polar mount or actuator is considered a huge bonus for and much better on my wallet.
Mickha
North West
Does it automatically include the Channel master adapter plate or do you have to request it?
Costactc
Canada
You need to request it and it costs an additional 5 pounds.
So has anyone actually installed one yet?
Costactc
Canada
I just finished installing my refurbished 1.2m fortec with an actuator. I will be installing the motor and mount next week to start testing before an actual install takes place.
Sounds good. I may even buy a second motor if your results are good, so I can slap the Fibo 120 on it. My lack of presence at my parents' place along with lack of use means that the Channel Master PM and the actuator are looking a bit sorry for themselves....
Costactc
Canada
Costactc
Canada
I have decided to install the CM 1.2m dish properly. I have a pole in my garage from an older install where it wasn't plumb. There is a 3" attachment at the top of the pole where the HH motor will be mounted. I just applied the first coat of rust paint and will have to dig a hole of at least 3' for the frost line:
RimaNTSS
N-E from Riga
@Costactc After you cement the pole into the ground and hang relatively heavy dish on top of it, could happen that pole will lose its verticality which is not good for polar-mounted system. Did you think about that?
Costactc
Canada
The pole is 3 1/2" and is heavier then the poles I am using for my 3m and 2.4m dishes which are much heavier the the 1.2m CM. This pole would accomodate my main c band dish easily.
RimaNTSS
N-E from Riga
Just in case I will show you my adjustable pole made of INOX. There are actually 2 pipes to make pole stronger (one pipe welded inside another one).
