Portable satellite dish base
blademedia
Sky
Hello, I will be making a portable satellite dish base, three reasons for this, one it gets round planning permission two I can move it out of the way when not in use three it will give me more satellites,
Nothing started but ive picked a few bits up for the build, levelling system and wheels, I have a fair bit of steal work in my workshop,
From reading up the structure needs to be 6ftx6ft and it needs to hold 1.3 tonne this will be well on the top side of any wind conditions,
A rough layout of the build below I will update here when work starts
I'll follow this with interest BM....
I was thinking of instead of having such a large base area, say 5ft x 5ft, i would sink some flush fixing points either side of it's resting operational position to anchor it down ??..possibly
blademedia
Sky
Hello John, once you start putting fixings in the ground its classed as fixed PP would be needed, I guess you could leave it in view while the dust settles then do it.
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
If you were going to have a regular position for the dish ie at the end of path or trolley runway you could sink some plastic pipe into the ground at the four corners and then drop 4 locating pins into place for a secure mounting, when play time is ended remove the pins and wheel dish away. hopefully this would still be classed as Temporary! as the pins would be removable.
blademedia
Sky
I will buy 4 brake kits for the wheels I have
Searching around the workshop and garden ive found 4 lengths of strong pipe, the wheels plates could not be better need to cut it all in 6ft lengths now
Yep, thats the sort of thing i was thinking about ..... you described it better :)
blademedia
Sky
If on driveway that would be easy, make construction on 2 ton pallet truck jack it up to move it I have no view of satellites from my driveway
Terryl
Custom built PC
Make it capable to hold 1300 liters of water, that way all you have to do is drain it to move it.
Make the wheels retractable, wheel it out, retract the wheels fill it with water your done, drain it to move it.
blademedia
Sky
Found this steal beam in workshop today it should do as king post, will use the vertical holes in base for levelling needs cutting to size
blademedia
Sky
Laid it all out today to get an idea how many bolts needed and to see how I will fix the levelling system, all 4 corners will need work to take 450x450 paving slabs, I have around 70 removed from where the decking is now, I am estimating around half tonne of steel to this point will weigh it before fitting.
Archive4
Just a thought, If you have a retractable pool?
I know this is a serious thread, but I could not resist.
I´ll bar myself from the forum!
