Possible elevation problem on motorised dish?
Tony1A
Never going back to Sky TV. Ever!
Somewhere In County Durham
Humax HDR1100S Freesat Recorder. Medion HD satellite box with Gibertini 1m motorised dish. Triax TD78 for Freesat. Triax TD64 for Freesat to 3 rooms. 2 Panasonic Freeview+ HD recorders.
North-East England, UK
This got me thinking. I was looking through the channels on my motorised TD78, and noticed that Vintage TV and others on that 28.5e transponder were low quality. Those of you who read my recent post know that I've had a slight problem with my fixed TD78 on Sky and the problem was elevation. Just wondering if I have the same problem here. Also, trying to tune in 26e is a pain as Astra at 28.2 keeps coming in and wiping it out. Thoughts please. :)
Mickha
North West
26E might be a problem, on a 78cm dish, especially if it's raining.
What signal quality/strength readings are you getting, on 28.2E, from the strong FTA channels, like BBC, and Vintage TV? I have to admit I rarely visit 28.2E and have never heard of Vintage TV.
Tony1A
Vintage TV is on Eurobird @28.5e. I'm getting about 40 something % which is low.
skomedal
This and that
thule
If you mean vintage tv transponder 11261 am getting 74/98, light rain, hummy 2000 hd, 100cm dish,
maximum 0.2 quad lnb, central southern norway.
Regards
Tony1A
It should be coming in strong because I'm in the UK. FTA box is a Technomate 5402HD.
Piltdownpaul
No.1 Spike Milligan Fan
It does for me-what you need is a sensitive signal meter and flex that dish slightly!
Tony1A
You may be right there, Paul! All I have is two Silvercrest SL65's (used one to set up this dish) and my Satlink Satellite finder.
Ghostleader
Glasgow,ish!
LOVE the SilverCrest SL65, Anyway back to the case in point, Vintage TV, 16 mile outside Glasgow, ISS perforated 80cm dish focused on 13E with a massive (Thats not going to work they said....) 15.2 degree offset Inverto Black Ultra quad LNB I get SNR: 53% on Technomate TWIN with Vix 3.0 build version 683, and off the same quad but with a direct feed not coming through the DiSEqC switch I get 73% quality on the Skybox F5 In the bedroom. I also have a motorised Zone 2 Triax $ky dish and I get it at 65% AGC also on the TWIN with that one just to prove me wrong its fluxing between that and 67% as I type this lol, but the cloud cover is rolling in as we speak, more rain is on its way......as per.
Mickha
North West
Have you tried nudging your dish, East/West, using the motor, to improve the signal?
It sounds like your dish is not tracking the satellite arc correctly. What are your signal strength/quality readings on 42E, 39E, 0.8W and 30W?
Tony1A
I'll have to get back to you on that one Mickha. Will check those today.
satelliteman
Worth also checking the LNb skew at reference. It should be at 0 degs.
Sent from my Galaxy S4 GT-I9505 using Tapatalk 4
Tony1A
LNB is at zero skew!
Tony1A
Signal levels on said satellites 45e/39e/0.8w/30w are fine. But 26e is getting splattered by 28.2e.
satelliteman
Pushing it with TD78.
Tony1A
Will probably end off replacing the TD78 with an 88cm or a 1m. But not until next year! :)
hairybadger
Bricoleur
46.1N 6.4E
see sig
Well a larger dish at least will give better directionality and so 28E will be less likely to interfere with 26E (once aligned correctly! :) )
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
TRIAX TD78
Frequency Range (GHz): 10.7-12.75
Gain (@ 11.7GHz): 37.1dBi
G/T (NF LNB 0.7d:cool:: 17.3dB/K
Offset Angle: 26 degrees
Elevation Range: 10 degrees-50 degrees, 45 degrees-80 degrees
Beamwidth: 2.6 degrees
Windload (@ 42m/s): 619N
Mast Dimensions (mm): diameter32-50
Dimensions (cm): 57x78
the beamwidth is an issue aswell as the official footprint saying 90cm for BADR4 and 120cm for poor weather fade margin and up to 160cm for northern scotland and western eire but as we know the footprint maps can have huge descrepencies. ive found a motorised dish is never as good as a fixed dish on 1 orbital slot at receiving the signal as its a compromise when tracking the arc although its marginal differences . when you go to a larger dish you would be better going to 1m like the gibby or orbital or even the td110 imo. this is the fun of the hobby trying to squeeze every drop of signal from your system and tweaking it to perfection... enjoy!!
Tony1A
Very true, Gibertini! :) Hairybadger! It seems my motorised TD78 is aligned right. It's just a tad too small.
skomedal
This and that
thule
Then explain low reception in post 1 with this dish
Regards
Piltdownpaul
My td88 does well with 26E,only in serious weather does it struggle,a td110 needs to be out of view of planning authorities unless you have agreeable neighbours. (My td 88 is 88x95cm i think).
