aceb
- Oct 2, 2007
Prof Tuner 7301 /
- Sussex
I think I've got my model numbers correct. The LNB bracket on F-i-Ls Mk4 dish has snapped on the hinge part of the clamp and I need to replace it as no amount of cable tie and gaffa tape is holding it firm. It's on the chimney due to trees and the gulls perch on it! The Mk4 is the 3 sided version that snaps on over the LNB arm and has the spirit level on it, yes? Fleabay only seems to sell adapters for newer 37MM LNBs to be used on Mk3s and these slide into a rectangular 4 sided LNB arm.
From what I can see the cheapest way to buy the bracket is complete with a quad LNB for around £7, I know it's not going to break the bank but would rather just pay a couple of quid for the plastic bracket if I can find one. Any one able to point me in the right direction?
