SES 5 (4.9°E) Reception reports please and map
SatSearcher
West Yorkshire
Results as follows, with 1m dish in Halifax, West Yorks, using TBS5925 card.
11265H 7.7dB Locked
11265V 7.9dB Locked
11305H 7.6dB Locked (Just about!)
11305V 7.9dB Locked
11345H 7.4dB No Lock
11345V 7.7dB Locked
11385V 8.1dB Locked
Signal levels taken in between showers, was not raining at the time, but some moisture still on dish & LNB. Looks like the cutoff point on these is around 7.5dB
Street, Somerset, 1.2m Fibo, Dr HD F15
11265H - 2.5dB no lock
11265V - 2.3dB no lock
11305H - 2.0dB no lock
11305V - 2.2dB no lock
11345H - 1.7dB no lock
11345V- 1.7dB no lock
11385V - 1.5dB no lock
Retired Mod
www.timo.me.uk
I can see a pattern forming with a north/south divide. Looks like 1m is borderline even up north.
It would be nice to have a few more reports from central Europe.
mar-val
Slovakia,Zilina
Slovakia ,Zilina, 115cm PF dish,Invacom twin,no problem...;)
strs65
Decoders: VU+ Uno, DR.HD F15
DVB cards: TBS6983, TBS 6925
Dish 1: Tecatel 1.10m
LNB1: Smart Oxid
Motor: Amiko DM3800
LNB2: Invacom QDF-031
Greece (Crete - Chania)
Just for the record, the Nordic beam of SES 5 is almost non-existent here (the frequencies are barely visible on the spectrum, none of them is strong enough to lock), in contrast with the frequencies of Astra 4A's Nordic beam (most of them are receivable here).
Greece, Chania (Crete), 1.25m Gibertini, Inverto Black Ultra single, Technotrend S2-1600 DVB card.
Retired Mod
www.timo.me.uk
Even non-existent reports are welcome!
Sadly I cant give a viable report even tho Im well inside the northern split and should get summat.
My 5E lnb is a offset on a 1m aimed at 9/10E and I cant even get any of the Astra 4A Nordics! Even the 4A FSS beams are extremely marginal
AS, in the interests of science though......
Yes I know.....
When I get some decent weather I'll spin that dish round & have a look :D
pontiend
Contibruter
south yorkshire
It is banging it down here.
Signal levels are down from 75/74% to 67/68%
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
11265H - 23%SQ no lock
11265V - 19%SQ no lock
11305H - 23%SQ no lock
11305V - 19%SQ no lock
11345H - 22%SQ no lock
11345V- 18%SQ no lock
11385V - 21%SQ no lock
cloudy/overcast atm and after a heavy downpour
TRIAX TD110/TM5302HD/INVERTO BLACK ULTRA TWIN/TRIAX TX100
near Manchester,North West UK
Odd... I am sure vipersan received these in Manchester on his 110 triax. Wonder if nelson_b can receive these on his 1.2m
Dish: Triax TD88. LNB: Black Ultra. Source: TBS6925 PC Card
Weather: Overcast, raining.
Verticals are somewhat weaker than Horizontals, no lock on 11,345V.
SQ figures as shown in Crazyscan.
Retired Mod
www.timo.me.uk
I'm not very good an interpreting these scans. So you're getting a lock on everything but 11,345V?
Yes, but need at least 7.7dB for lock with existing dish/LNB. Can't try the Gibby 1.2m at present, actuator stuck.
Retired Mod
www.timo.me.uk
OK thanks, I was just a bit surprised since no one else seems to manage it with a small dish in the south. I guess the easterly location is helping and perhaps your equipment is more sensitive?
Didn't do any fine tuning of the dish, just swapped a KA LNB for the Black Ultra. I would think the Gibby could lock the 11.345V.
iandoh
Pärnu. Estonia/Burgas, Bulgaria
1m Mutlibracket (19e, 13e, 10e, 9e, 4.8e) & 1.2m @ 28e
All K here obviously. I could give specifics if needed
