Signal problem re UK tv in South of France - Dec 2013
TJExcalibur
Out of this world.
Southern England
Not sure how to use this forum to update my own page, but need to let all people who have replied to my original post that my tv signal has returned and all channels are back. I did nothing and have cancelled the visit from tv man, although one evening last week the signal faded again for some channels but came back again. Just hoping it will stay ok. Thanks for all your kind replies so far.
Ah well another happy former UK person who has moved to France. I am sorely tempted to do the same and mulling it over now I have finished my 10 years of hard labour on the house.
Check out 2E and 2G first!
sonnetpete
wordpress.com
Normandy, France
TJ, I know someone who is probably selling up in the next couple of years and has a ready made dish farm.....
TheProfRobin
Skybox, Sagem Freesat, Humax Canal+, MacBookPro, iPad Air etc.
Castillon du Gard
Judith, Given the timing of your original post and the fact that you have a big dish and you were away during the November big winds, I suspect your dish could do with a re-tweak to get it accurately aligned again. If you are losing signal in medium rain, this is a sure sign. Being a big dish, it only sees over a narrow angle and can easily get off its peak in a strong mistral. I had a total loss with a 95cm dish near Avignon in Nov, but 15 mins with a spanner and a meter and it all came back. I believe in having big dishes where you can easily get at them. They don't mix well with ladders in my opinion.
JudithP
Humax freeview with 1m satellite dish to pick up UK tv in Toulon, South of France
I too did 16 years of hard labour on my little house in Pagham, Bognor Regis, UK, and suddenly it was worth enough to get me a little house in La Seyne sur Mer. Almost a straight swop and God got me here, beyond my wildest dreams, and I am really happy. The french neighbours have welcomed me with open arms, I have had a hip replacement Oct/Nov and my english tv seems to be working fine now!!! What more could I ask for.
JudithP
Thank you for kind advice. I realise that it would be easier to have the dish on the ground but not possible for me. Meanwhile, all my channels, except Channel 5, have been back since I got home in December, in spite of heavy rain and wind so it is still a mystery as to what happened.
TheProfRobin
Castillon du Gard
I had another think here. Both Sky and Freesat download firmware updates to your box, usually during the night. If your box was off while you were away I mean off and not on stand by, then it would not have had any updates regarding channel frequency changes and so you would get blanks on any channel that had changed. The first night you left it on standby, it would have got the updates and everything would be working again next day.
The next test is 2E. It has been parked at 43degE for prolonged tests but started its drift westwards a few days ago. Monitoring its position & speed of drift, it should be in its right position at 28.2E in about 10 days. So expect a bit of bother at the end of the month. That will be the time to tweak the dish first. If that does not bring back any missing ones, then it will mean a bigger dish, provided those already with bigger dishes say they have a signal.
Astra's predictive map showed a useable signal in Lyon (60cm dish) so I believe we shall be all right on S coast of France. Scandinavian and Southern Spain viewers might have serious problems.
And what you say about the French above is completely true. I live in a small village & although they moan about miscreants, they do not have anti-social problems on the scale of England. They maintain politeness and family standards that the English could do well to re-learn. I have had nothing but courtesy and friendliness, possibly helped by the fact that I insist on using my poor, but improving French and participate humbly in village life. I even went to the half a pig & legs of ham bingo.
That will be for the Pan-European beam. The spot beam is expected to be similar to 2F's and will cause similar problems with the Beeb in the fringes to that which C5 is now having.
My wife and I love our little place in France. It's in a little hameau of five dwellings a couple of miles from the village and when we're down there the silence can hurt your ears even though we're only five minutes from an interchange on the A7.
Although we originally planned on moving there permanently now we think we have the best of both worlds. As I still have to work we can only get there during the holidays which, as I work in a school, are fortunately long. That way we can go to the concerts, films and theatre showings that are just not available in France.
TheProfRobin
Castillon du Gard
Hi Paul, I am pretty sure I checked the spot beam map - although reality of course can be different. With a 95cm dish 20 miles NW of Avignon, I have no problems to date with any channels, unless we have one of those 6 inches of rain in 2 hours type of downfall.
astra2f-uk.jpg If you mean this map then I reeckon it's more like Auxerre or thereabouts. And this is important because we know that the spot beam falls off in strength more rapidly than 2D.
Our French place is not too far away from you and I recently installed a Triax TD88 in place of the previous 80cm (equivalent) as I was losing channels in moderate rain. My setup uses a Quattro and multiswitch so I need a bit more signal than an ordinary LNB. I could probably do with a more modern Quattro as well as it's at least 5 years old.
Anyway, the signal is better but I still lose the 2E spot beams in moderate to heavy rain so I'm considering jumping past a 90cm dish and going straight up to a 1m dish that I have hanging around here.
TheProfRobin
Castillon du Gard
View attachment 61065 If you mean this map then I reeckon it's more like Auxerre or thereabouts. And this is important because we know that the spot beam falls off in strength more rapidly than 2D.
hairybadger
Bricoleur
46.1N 6.4E
see sig
FWIW: I can pick up everything, even Channel 5, on a 60cm with black ultra 20km SE of Geneva. Not much rain margin, though :)
peapod1
Wiltshire
Edision Mio 4k UHD, Fracarro Penta 85 with Inverto Black Ultra LNB. Technomate 2600 motor. Technomate 6902hd and 1m Gibertini in France.
Wiltshire UK and Bandol, France
Well here in the south of France, just inland from the coast near Bandol, I've just completed phase 2 of my upgrade. Phase 1 replaced the 85cm perforated dish with a 1m Gibertini XP dish and Black Ultra lnb. Phase 2 has added a Gibby multifeed holder (well engineered and robust) to pull in Astra 1 and Hotbird.
With a modicum of fine tuning to peak the signal on Astra 2, I'm getting solid reception on none-HD 4Seven on 11126 and equally on Channel 5. Both held up well in last weekend's torrential rain.
Good result - time to remove "Cheshire" from your Profile? ;)
peapod1
Wiltshire
Profile updated to reflect that, post-retirement, it's now approaching moitie moitie.
hairybadger
Bricoleur
46.1N 6.4E
see sig
Tivù - should you not be a "Tout Rond Bon Oeuf" (not "ronde"). I know it's franglais rather than French but still :)
SWMBO has confirmed your correctitude and I shall put it right forthwith!
peapod1
Wiltshire
SWMBO??
Shouldn't that read La Directrice? :-)
Does she not like that! :-lmao
