SKY HD box Amstrad 890C - settings
samoloko
1.8 PFA
EU
got few questions about SKY + HD box Amstrad 890C
when you are on tv channel how can you get transponder details - freq, pol, SR, FEC and signal level
how can you get HDD details from menu - model, capacity
can I remove HDD and box to work properly
davemurgtroyd
Oxford
Oxford
Only the signal level can be obtained - "Service" "Right Arrow" "Down Arrow" "Signal" - for the usual owner this info would be useless as the box automatically tunes to channels from info within the data broadcast with the EPG
You cannot
On some versions of the firmware it is possible although you will not get an EPG (except Now and Next) as it is downloaded to the HDD - try it and see if yours will.
