Help Required Sky signal
sep990
DM600
Hi
We had the roof done today and it seem like the builders may have accidently touched the dish.
I do not get any channels Inc BBC One. The snr is shown as 65%, acg as 85 and ber as 0. Does this mean the dish need alignment or could it be something else.
Thank you
If builders have been working close to the dish its odds on its been knocked.
Howevere try pulling the plug out the wall, waiting a couple of minutes & rebooting it. You may get lucky, although those signal reading suggest you are picking up one of the other satellites.
sep990
DM600
Thanks. Tapped it a bit with a long Broom and is has started working. Need to get the dish changed as it is very old.
Thank you for your help.
If it ain't broke ................
When you can get close up to it, just coat the swivel bolts with WD40 and later on nip up and tweak them a little tighter.
BLUEPLATINUM
Maspalomas, Gran Canaria
Ha. Wish I could just do that with my big Channel Master to improve 2E/2F.
Retired Mod
www.timo.me.uk
Useful things brooms. I used one to clear the snow away from the LNB today to get 2A south back...
