simonutd
- Mar 13, 2014
- Age
- 43
- Sky HD,
- UK
Well my problem is as the Title says,
I have a single coax coming in for sky, and I have now got sky HD, which means I need two cables, so I looked on the internet and this is what I found
http://www.diy.com/nav/fix/electric...ers/Philex-Satellite-Splitter-Six-Way-9686737
I know, B and Q are a rip off and not great quality, but it was late and open so I went and got one,
Well the problem is it don't work, if I attach one coax to the splitter it works, but at a much reduced signal strength, if I attach both, then I get nothing at all, myself I think its problem 1 or more of the below,
1) its broke
2) I don't know what im doing
3) I not wired it right, but how hard can it be with 1 input and 6 out puts
4) I don't know what im doing
I would be grateful for any help, and if I you can recommend a better item then that would be fantastic,
1) its broke
