Tooway broadband dish for tv reception
Discussion in 'DISH SETUP: Single sat, Multi-Sat & Motorised' started by jpsr, Dec 20, 2011.
  1. jpsr
    jpsr Regular Member
    Aug 27, 2009
    239
    7
    My Satellite Setup:
    1.2 channel master, cm polar mount, 12 inch actuator, Andrews feedhorn, Inverto lnb, Superjack positioner, Dreambox dm 500s, Protek 9600ip, 1m channel master with black ultra & 1m gibertini with technomate twin output lnb on astra 1/2, TM 5200 & 1000
    My Location:
    Mullingar, Ireland
    I am looking at buying a secondhand 1m channel master dish that was used for broadband.
    Is the lnb used for broadband able to receive tv transnissions, The lnb has 2 cables coming from it.
  2. Chris76
    Chris76 Specialist Contributor
    Dec 3, 2009
    330
    2
    My Satellite Setup:
    Vu+ duo with a 300gb hdd also dm500 and tecnomate 5200 with a 1m and 1.1m motorized dishes and minidish fixed to 28.2
    My Location:
    Belfast
    The lnbf is KA band you will need a KU band lnb for normal transmissions. but the lnbf will be useful for soarsat as this service uses KA.
  3. Tivù
    Tivù Tout Rond Bon Oeuf Staff Member
    16,659
    1,929
    My Satellite Setup:
    My Location:
    N.Yorks Moors
    ............. and Ka Band LNBs are not cheap, so do not bin it!
  4. 2cvbloke
    2cvbloke vroooooooom!!!
    Jan 5, 2006
    7,101
    177
    My Satellite Setup:
    My Location:
    Near Pontop Pike, Co. Durham
    If it's anything like the 1M Channel Master/Andrews satellite broadband dish I had, all you need to do is pull off the Transceiver assembly from the feedhorn and then bolt on a C120 Flange LNB of your choosing... :)
    See the pics below, first is the appendage my dish had, and the 2nd is the same feedhorn but with a tiny little Inverto White Tech C120 LNB fitted, but you can use whatever C120 LNB you wish... :)
    (Unfortunately I never got to use the dish due to landlord issues and security issues with kids using my yard at the time as a shortcut from back street to front street)
  5. saj1985
    saj1985 Member
    Dec 23, 2007
    419
    101
    My Satellite Setup:
    Dreambox 800HD SE, Dreambox 500S, Skybox F5S, 90cm Solid Dish, Tm2600 Motor, Inverto Black Ultra LNB! :)
    My Location:
    Lost...
    hey peeps, just curious,
    what are these tooway dishes like? any good?
  6. wod
    wod Specialist Contributor
    Aug 7, 2005
    3,996
    My Satellite Setup:
    My Location:
    yorkshire
    i have one got it off ebay and its just a channel master dish with the vsat kit of which i took it off and put a inverto black ultra lnb on the dish for tv reception.
Share This Page
Click here to support our sponsors
