TurkSat 4A/3A@ 42 East
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Just rescanned, got them as well as cnbc-e and e2 which is a really nice surprise :D
killdeer
West Lancs UK
Technomate 5402 M1, Vu+Solo2, Humax Foxsats HD&HDR.
Triax TD110, Inverto Black Ultra.
90cm Fibo with Invacom 0.3dB LNB (not up and running yet.)
62 East to 61West
Lancs
10966H 15200 and 11054H 30000 are booming in here, West Lancs UK, this afternoon.
Laser
Try also 11996 Vertical 27500.
Fils TV often has English films on there.
Need to select English soundtrack
nelson_b
Contributor
Nice that this transponder is now changed to a west beam -- apart from the t.v channels that you mentioned -- 11054H 30000 also carries Radyo Eksen -- which in my view is one of the best rock radio stations available :) -- content is similar to bbc 6 music but without all the chat --- now that this t.p has switched from east beam to west beam it makes my 1.8 Alcoa prime focus dish somewhat redundant - as this has been its sole use for the past 3 years -- l.o.l.
Nelson_b, then enjoy this package while it lasts, it's planned soon to move to the 4A Turkey beam.
How about 12422H, can you get it with 1.8 m?
nelson_b
Contributor
Thought it might be too good to last --" hvdh" --- :(
Not a flicker from 12422H for me here in north west u.k.
regards ----
mar-val
Slovakia,Zilina
12446 H 2400 3/4 dvbs-Farda TV.
Good lock with 6 to 7 dB on 12446 H 2400.
It's at the expense of the strength of 12422 H, because normally that starts to lock by this time of the day. It's the same physical 72 MHz transponder.
But very strange, my F16 refuses to give a picture on Farda TV, while the TBS with VLC does?
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Same here my F15 says no 'Audio or Video' with a 8.5 db signal on a 1.2Dish, whilst both my Dreamboxes...one with a 1.2 Dish and the other with a 1.5 Dish give a picture.
mar-val
Slovakia,Zilina
New TP, 12197H 12000. 3 scrambled channels.
mar-val
Slovakia,Zilina
Hmm,now I see, wrong picture...o_O
This is the new TP.12197 H 11400
If you have curiosity to get 5 radios from three transponders,you can check with any TBS dvb-s2 card on Turksat at 42.0E.Of course that Blindscan does not find all these transponders,only two or three in the best case.If the signal is strong it is no problem to find all these freqs.You must manually scan,like I did on Hispasat.You have found the end of the wire from the spool
The rest comes by itself.
My test is with TBS6925 card:
11556.784 KHz,405,5/6-TRT Anatalya,
11557.436 KHz,395,5/6-TRT Cukurova,
11558.033 KHz,410,5/6-TRT Erzerum,
11558.542 KHz,390,3/4-TRT Trabzon,
11559.145 KHz,400,5/6-TRT Gap
mar-val
Slovakia,Zilina
Empty test carrier 12140H 2222.
mar-val
Slovakia,Zilina
Horizontal high scan.
