TV + FM/DAB + Satellite triplexed surface outlet plate
spike47
Sky dish on Freesat and Aerial on Freeview .both piped down to lounge TV and Bed 1 and a Sat cable to Bed 2 .
Skelton , Saltburn-by-the-Sea Yorkshire
Hi
I am wanting to buy a back plate to put a cable from my Aerial and a Cable from my dish into my bedroom ,the question is , the back plate I have seen as below , only has one inlet ! . " TV + FM/DAB + Satellite triplexed surface outlet plate ", so how do I connect my Aerial and Sat cables to it ! .
cheers
spike
If you have two sources (satellite and terrestrial TV) you need a diplexer to combine the signals into one cable. If you a third source (FM radio and/or DA:cool: then you need another triplexer to combine them.
If you already have two cables into the room then it might be an idea to buy a faceplate with two separated outlets or even a blanl plate and then drill two holes and make your own. You need two F type barrel connectors and two F plugs and will probably give the best connection.
You can use two modules in a grid plate, one satellite and one UHF, or a triplexed plate with a second satellite feed. www.satelliteandaerialsupplies.com/product/?s=global-triplex-tvfmif-outlet-plate-return-4-output
Or you can use the one you show, using a diplexer externally to combine TV and satellite into one cable. www.satelliteandaerialsupplies.com/product/?s=global-dip2-ifuhfvhf-combiner
Or perhaps a brush outlet plate www.satelliteandaerialsupplies.com/product/?s=labgear-70435-brush-cable-entry-exit-faceplate-1-gang-white
spike47
Hi
Thanks for your reply , when you say , " you need a diplexer to combine the signals into one cable. " not sure where that one cable would go , into the back of the Triplex as in my first Post !! , what I need is a Sat feed to my Digi box and a UHF feed to my TV ( built in freeview ) .
spike
The diplexer would go outside, then you could use that plate inside.
spike47
Hi rolfw
Thanks for that info , now I understand , I think I will just put another box in the room with another cable into it .
off back to bed now .
cheers
spike
Why not do as I suggested and put the two cables into one box but then put a plate on with two outlets? It's dead easy to make your own up with a blank plate, 2 F plugs and two F barrel connectors with nuts. Drill the plate symmetrically so it looks nice, I think a 9.5mm (actually 3/8") drill is needed. Your only problem is getting hold oif the barrel connectors with nuts - most come without and you have to search them out.
spike47
Hi Paul
Yes that is the best and neatest way , off now to get the bits .
thanks again for your help , what would we do without FORUMS .
cheers
spike
