1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
U bolt for 3 inch pole
Discussion in 'DISH SETUP: Single sat, Multi-Sat & Motorised' started by jpsr, Aug 7, 2013.
  1. jpsr
    jpsr Regular Member
    Aug 27, 2009
    239
    7
    My Satellite Setup:
    1.2 channel master, cm polar mount, 12 inch actuator, Andrews feedhorn, Inverto lnb, Superjack positioner, Dreambox dm 500s, Protek 9600ip, 1m channel master with black ultra & 1m gibertini with technomate twin output lnb on astra 1/2, TM 5200 & 1000
    My Location:
    Mullingar, Ireland
    Does anyone know where I would get u bolts for t&k brackets that allow a 3 inch pole.
    The t&k brackets i have, there are u bolts that allow a 2 inch pole, the holes on the brackets are wide enough to fit a 3 inch pole, need it for a 1.2 channel master.
  2. RimaNTSS
    RimaNTSS Specialist Contributor
    Jan 7, 2009
    1,510
    690
    My Satellite Setup:
    Some SAT-related hardware.
    My Location:
    Brussels
    jpsr likes this.
  3. Tivù
    Tivù Tout Rond Bon Oeuf Staff Member
    17,118
    2,230
    My Satellite Setup:
    My Location:
    N.Yorks Moors
    Pop into any Exhaust Centre and ask if you can rummage through their fitments bins.
    jpsr likes this.
  4. RimaNTSS
    Jan 7, 2009
    1,510
    690
    My Satellite Setup:
    My Location:
    Brussels
    And, BTW, it is not so difficult to make any U-bolt yourself, just take threaded bar and properly bend it ( I've done it couple of times).
    jpsr likes this.
  5. jpsr
    jpsr Regular Member
    Aug 27, 2009
    239
    7
    My Satellite Setup:
    My Location:
    Mullingar, Ireland
    Good idea, I'll get threaded bar, thanks.
  6. RimaNTSS
    Jan 7, 2009
    1,510
    690
    My Satellite Setup:
    My Location:
    Brussels
    Just one advice- take long bar, will be easier to bend. Cut not needed parts after bending. It will, maybe look not as from a shop, but works same. On the picture- original from left side and self-made right one.
  7. jpsr
    jpsr Regular Member
    Aug 27, 2009
    239
    7
    My Satellite Setup:
    My Location:
    Mullingar, Ireland
    Good job, does the trick. I'll have a go at it in the next week.
  8. wod
    wod Specialist Contributor
    Aug 7, 2005
    4,026
    87
    My Satellite Setup:
    My Location:
    yorkshire
    I used 3 inch exhaust clamps on my setup.
  9. Tivù
    17,118
    2,230
    My Satellite Setup:
    My Location:
    N.Yorks Moors
    Yep. My Post #3 wasn't tongue in cheek :D
Share This Page
Click here to support our sponsors
