uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
Of course they could be REALLY nasty & change the keys 10 minutes before kickoff of the first game :-lmao
Deso
1.2m Generic dish, Sky+ HD and Technomate TM5402 HD box.
Fuerteventura/UK
They could put us out of our misery and change it 10 minutes before the kick off of the first England game. :-buttkick
fireballxl5
MKDigtal XP1000, VU Solo, Skybox F5 - 1.2mtr dish on 28.8 and 1m on 27.5
Southern spain
Hello All
I'm new to this forum which I found whilst I was looking by looking for help on Intelsat 907. I figured that surely it can't be that hard to setup and connect as I managed to setup my own Enigma 2 box to work for S*y, how wrong was I? I didn't want to touch the 28.2 setup so I bought a 1 metre dish and managed to line up to 907 then ran a scan and got a list of channels. I created SoftCam.Key and constant.cw and plonked them into /var/keys as everyone said you should when using cccam.cfg and then nothing. So after a couple of days of searching for an answer I came across this site where everyone seems to be able to access the satellite. I could get a local guy to sell me another box and install a solution for me for a few hundred euros, but I just want to be able to do it myself and say I did that! Can anyone please spend a bit of their time to perhaps look over what I have done and point out to me where I have gone wrong? The beers would be on me :rolleyes:! I would like to use my MKDigital XP1000 or the VU Solo if possible.
Thanks in advance
digi247
NW
see sig
To open those channels on an Enigma2 receiver you are going to have to use OpenPLI image and Oscam-Y-Mod for it to work, There is a massive thread over on the PLI forums about this and how to get it to work
But keep an eye on the threads as it could go dark again at any moment!
fireballxl5
Southern spain
Thanks for the info about the Oscam-Y-Mod, this is the first time I have come across this (whatever it may be), I shall dig deeper, that's half the fun of it. I've been reading some of the comments made on the "big challenge" thread on the OpenPLi forum, quite a bit of the seriously techie stuff is a bit beyond my skillset and after reading some of it you are left wondering what all of those words actually meant.
And I agree, just prior to the World Cup all will stop, it is the way of things.
mr420
DM8000HD . Vu+ Solo HD
T90 1w 5e 13e , Triax 110 + Inverto Black Ultra Quad
Drammen , Norway
Oscam-Y-Mod isnt safe since i read some where it has backdoor. I am not sure if thats true but i am not going to use it.
I used biss keys with Premier League HD channel on 9e with orignal Oscam. I think u can use orginal oscam with configs from openpli
digi247
NW
see sig
You could probably say that about every Cam emulator Going then, AFAIAA i have never had any problems with the Y mod version
radicaldoc
1.2 gilbertini with VU+ Solo2. 60cm with Spanish TDT from satellite.. and channel master 1.0m for 27.5 hopefully..LOL
Horizon USB Plus
Nr Martos, Jaen. Spain..
can someone explain where i put the key for this i have a set up on my solo2 openpli 4 and now have installed y mod. where do i telenet the key to ??
kota
VU+ Solo2,Humax HDCI2000,Astra2 1.80m Famaval dish/Inverto Black Pro,Astra1&Hotbird 90cm dual lnb dish,Astra3 1.20m dish,Intelsat 907 80cm dish, Hispasat 60cm dish.
Sintra - Portugal
keys should go in the etc/tuxbox/config/oscam.ymod folder (attributes 775) and then in the subfolder oscam.key (attributes 644)
radicaldoc
Horizon USB Plus
Thanks for your help bud.........
radicaldoc
Horizon USB Plus
Although i don't understand the reference to (attributes 775) and (attributes 664)??
and on my system i get down to oscam_ymod folder and that's it there is no sub folder oscam key.
look up chmod on wiki - its just setting of permissions on linux files.
radicaldoc
Horizon USB Plus
What was that something just went whoooshhhhh over my head that was close...LOL Is that page in Dutch.... :)
Well i just surprised myself and changes permissions of oscam_ymod folder to 775 from 755 and created a folder inside that called oscam key with the 644 permission... LOL
So how do now put in the just paste it in the oscam.key folder??
in the oscam folder there is a file called oscam.key as well but this is just a file. how do i open this file or any of the others to look at and edit if need be??
radicaldoc
Horizon USB Plus
So where do i look to find out how to create the oscam.key file i have the key but don't know how to create it and i don't think i just wang it in a folder called oscam.key i am assuming i will need to make it to drop into my oscam-ymod folder. i have done a search of the forum but nothing has come up....!!
fireballxl5
Southern spain
Hi Kota. I've seen many helpful posts from you on a number of forums, may I ask if you are using Vix? I have tried Open PLi and BH but I always return to Vix and based on some of the comments I have read the suggestion is that the services from 907 are only available via Open PLi, though I seem to recall reading that you had managed to get it working on BH/Vix (I can't remember what you might have written). I would like to use Vix so would appreciate a heads up if you have managed to get it to work.
BlindFaith
TBS 5925
IMHO this forum is not the appropriate place to discuss specific recipes where to put keys.
Mod. Note: If Members have concerns about the nature of Posts, please use the Report feature provided for the purpose. That will alert Staff, who can then assess the issue in due course.
kota
Sintra - Portugal
All the latest images based on openPli are OK for this as long as you install dvbsnoop once flashed, VIX included. Never managed to get it to work with Black Hole images so I gave up on them. At the moment I'm using openATV 4.0 which I honestly think is the best image around for the Solo2.
Also, installing oscam-ymod requires different methods for every given image even though they're all based on openPli so it's better to install it manually but you should know where each of its folders goes to.
The easiest way to get this going with minimum fuss is flashing openSpa 3.1 image. It's got everything you need from their own feed, configs included, almost like plug and play. The only snag is that the default language is Spanish but you can change that to English latter on.
Cheers
EDIT: something I said is not correct. I did manage to make it work with BH but never been able to clear the HD channels AAC-HE sound.
radicaldoc
Horizon USB Plus
I may take a look at the openSpa 3.1 Then if you think it is better Kota...
