uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
TopGear
GM Spark Triplex - 90cm dish @ 0.8w, 5e, 13e, 19e, 23e, 28.2e - 90cm dish @ 27.5w
Estonia
those amikos running enigma2 image?
Then backup channel list with dreamboxedit and upload to the second box
TedWard
Skybox v8,Skybox F3,1.2 metre dish,80 cm dish
Spain
Just an update guys,couldnt get a Skybox F3 to work,so bought a GI Sunbird off local guy ,plugged in and everything working good,thank you very much for hints tips etc very much appreciated,,,,,,,,,,,,,
MARK
Tenerife
www.satellites.co.uk
Sky HD+,Dreambox500HD,800SEHD,tm5402hdCI+SUPER+lots of other STB's,1mtr ISS motorised
Pc's far too many lol
Good ole Blighty
Can anyone tell if they have biss code working on a AB Crptobox 550HD patched....
Regards
dvdfilm
1.5m dish
spain
What vu+ receivers (and enigma2 in general) are proven to work with these channels?
digi247
NW
see sig
its not the actual receivers themselves more like what image and combination of emulator you use, OpenPLI seems to be the favourite in combination with OscamYmod emulator
It also depends if the receiver will read the encrypted PMT file on the transmission - many wont.
Edit - corrected PMT incorrect info
BlindFaith
TBS 5925
PAT and SDTare not encrypted but the PMTs are. A standard STB will read the PAT and can determine the names of the services from the SDT but the STB will fail to read a PMT and therefore doesn't know the stream type and PID of an elementary stream.
If you can enter the ES_PIDs manually you can descramble the streams by a built-in emulator. If the firmware will also descramble the PMT, it can work like any other BISS encoded service, though BBC Satback is strictly speaking not BISS but both work with constant control words ;)
Oh yes - I meant PMT - its been a loooong day at work :D
Previous post edited for clarity.
dvdfilm
1.5m dish
spain
Has anyone tried with a cloud ibox3 with OpenPli image?
Deso
1.2m Generic dish, Sky+ HD and Technomate TM5402 HD box.
Fuerteventura/UK
Based on.........? :)
trigger
Puerto del Carmen, Lanzarote
30W, 27.5W, 7W, 0.1W
4.8E, 9E, 13E, 19E, 23.5E, 26E, 28E
Technomate 5402HD super
Bein Sports on 25.5E
FTE Mini S2T HD Analyser
Horizon HD S2 sat meter
Lanzarote, Canary Islands
Someone knows their stuff!!!
Key change today
MarkW
1.2 Galaxy,IBU single,Technomate 5402M3
Jesi,Italy
Is it just a code change,seems a bit early?:(
Deso
Fuerteventura/UK
Didn't last as long this time then. :)
The next question is, does this source know the new code? :-lol
Deso
Fuerteventura/UK
It looks like the beeb may be taking it a bit more seriously now. It was usually around 4 months between changes, but this time it has only been 2 months. Lets see how long it takes for the code to become available this time. :-buttkick
woborny
new codes already available....
Please DO NOT fill the thread up with requests for keys - we are not a key site & if the thread gets full of "keys please" it will be closed.
And no pestering anyone via pm either. There are plenty of sources for the keys. Anyone found to be pestering for keys will have their membership suspended.
BlindFaith
TBS 5925
Since a couple of days I experience intermittent error bursts with a 70cm dish in Berlin. Though there is hardly a drop of the SNR the error rate suddenly jumps up. Could it be the beginning of a dying TBS5925? (I had similar experiences with the 6925). Next week I can check the signal from my 120cm Echostar and compare it with a Prof7500.
I have the same thing happening on my Skystar card... not sure how indicative it is of imminent failure.
BlindFaith
TBS 5925
..different card, different location but same problem -> added noise to the uplink?
Sorry, I didn't mean I have this problem on this particular satellite/frequency. I get it everywhere. It doesn't seem to cause any issues though.
