Warning!!! Coship 2300 patch
poilus
hi jzurd0,
i've try use the 331 firm you say, but not good for my axil AD-600, i've a B38 boot
it will be perhaps for the next firm... :-)
cheers.
wwwvex
I have put the sw of strong 3680 in the coship 5300 a.It is ok!Is there file-emu sec 2? Thank you.
oxoid
can someone tell me if i can found a seca2 firmware for the coship 2300A BOOTLOADER 21 because the filecenter 1.6 doesn't work
it begins to upload but stop at bloc 97 on 515
does someone know if it's possible to upgrade bootloader 21 to ..34..39...
thanks for your help
jzurd0
I need SOMEONE WITH A TBOSTON 4500 with a WORKING JTAG.
Please let emails,or message me.
It´s VERY important for the AXIL users,(Seka2 related).
P.D: It´s near, Poilus...
kpakistan
this file name srt3680-331 look like jtag file bcz it have 2048 bytes while those file which r upload through loader have 2049 bytes. so i hope it works with my coship 2300b when i flash with jtag program
any sucess i hope share here .
dohc
error404 said:
Hi dohc,
I've tested ORF the whole sunday, and it works on my receiver. Where are you from? It easier for me to write in german or polish. Write me to not.found@gmx.net. I'll test the Morocco emu.
Regards
Hi error404,
do you received my e-mails?
Greets
Jo
fegro
Hello, Im new in this forum.
Today I got a new digital fta receiver called dsr5300.
It looks like the 2300. Is it possible to patch this receiver?
mfg fegro
fegro
Hello,
im searching for a patch coship_DSR5002_B29_NagraAU.zip
S02B-2.98R-B39.01_21.08.04.bin.
Thanks for reply
fegro
r0mek
Hello,
Nagra AU doesn't work since today.
I'm looking for new firmware.
Best regards
r0mek
wanders
Hello masters.
Has bought new Coship and at once a problem. I can insert software fon Pack Boston-Coship. My receiver
S02A-2.99R-B39.01
STS-MB.02A-SZLo.
Loading passes normally, but after start only the white screen and no channels and I can not cause the menu.
With Marocco patch I have gut screen, but sound is only noise.
Have you idee? Can be eat updated version Morocco-Earth software?
peles
legrandchauve vbmenu_register("postmenu_142207", true); hello
how can i have software :-) for dsr5003
please help me
Bingo2510
Coship 2300a Help
I have put in the Sofltware Marocco-Earth. There is a Picture but no Sound what can I do ?????
titi_lee
Bingo2510 said:
Coship 2300a Help
You can use the fw:
romb34_39pour 2et3 generation.bin and flash it with uptoolb34.exe program:
You can found them here
It's working on my AXIL AD600 (
B39.02).
Bingo2510
Thank you for your information. i have put in that software which you said, but it shows only 4 strokes on the display, and it dont start.
titi_lee
I don't have this problem with my Axil AD-600.
Which demo have you got ?
You could try this rom: firm S02A-2.96RB3902 STS-MB.02A-SL0 .rar
found here
