Zenega CD1004iS Boot problem
MICRO
dear, sir
zenega cd1004is data cord RS232 digram . send my email .thanks sir
INDIA
dishtv settop box software box to box download cord RS232 diagram
ved
v
hiiiii akdesarkar
sorry for late reply ya its possible to watch free to air channels in any firmware . no need to change sofware . sorry but its my bussines we cant share here
jamesq
Zee Dish TV
Dubai
There are 2 capacitors of 1000uf/10v. Both may not e faulty but just in case change them both to 16v or 25v.
You can open the decoder and easily unplug the power supply board and take it to a local electrician.
Thanks to all for the valuable information here.. saved me some bucks and the time....
manoj123sahoo
zanega-1004s
india
ved said:
hiiiii akdesarkar
dear friend will u help me to use zenega 1004is for without cam?
smdmoly
yes
india
rightsameer said:
hi, im from bombay, india....
thers a problem with my dish tv stb ( zenega cd 1004is)
at the moment its flashing a very dim yellow/orange light continuously for the past 1-2 days. its blank on the tv screen-no dish tv channels or anything for that matter-totally blank.
what can i do to fix this?
why is this happening ?
i think a couple of nights ago there was a power failure in my locality.
PLS HELP !!!
hi i am wasim
u r problem is boot file
pls chang boot file
akdesarkar
Dish TV, Zenega 1004iS
India
I am still in search a circuit diagram so that I can change it to FTA. I contacted somebody who was talking about Jtag. Any way if anybody can provide me a circuit diagram I shall be happy to proceed.
akdesarkar
India
I am in need of a Circuit Diagram A K DE SARKAR SKYPE: akdesarkar
smdmoly
yes
india
pls tel me
how to use stb softwear for zeenega is1004 with 232 serial pot
daemonkane
Dish TV , Zenega STB
INDIA
Thanks Guys. The DishTV support was giving me the BS about software update. Your thread lead me to the correct solution and I got my STB fixed at a local electronics shop in 10 minutes. He changed the two condensers, I guess they had flunked when there was a sudden voltage fluctuation.
The electrician said, he has put 2 condensers of 16v. Thanks a lot.
duggirala
DISHTV
VADODARA
ved said:
hi hsarp
no needs to change power supply.only change power supply filter cap.25v 1000mf.[:p]
Thank you very much, thats great! now It all works fine
prafuldesai
you do not need any hardware modification. All u need to do is to re-orient dish to insat4 for ur geographic location. I have done it for Baroda. Very small change in angle was needed and just keep watching on tv while realigning the programs u get. All DDplus DTH channels are received in good quality.
prafuldesai
all u need is to realign,slight -less than 1dgree-moving disch in right direction will connect ur dish to insat4 which will download all DDplus DTH channels.
duggirala
DISHTV
VADODARA
vandana said:
hi
i want to convert my cd 1004is zenega settop box of dishtv to operate for dth(free to air)
can anybody help me how to convert it in free to air
in the market some technicians are doing it,but i want to do it myself
please help me
first remove dish in put cables then power switch turn on start channel 115 (free of air number) then connect to in put cable
utkarsh
zenega cd1002s stb
dishtv
India
Hi i m from chennai
I have purshased zenega cd 1004is from Dish Tv
How do we reinstall its software to view free to air channel
skeyrock
all aboyt dishtv
dubai
hsarp72 said:
Hello all,
I am Dish TV user, using "Zenega CD1004iS". Past few days I am having trouble with booting this setup box. It starts with very dim and fast blinking orange light, slows down after sometime and and finally ends up with proper green light. This complete process takes about 5-10 minutes, which is quite frustrating. I consulted the experts and they advised me to re-install the software/firmware.
Can anyone help me with it? Is it possible doing it at home and how can we do it step by step.
Thank you for all those willing to help me.
-Hsarp
hello how are you i am abbas from dubai if you want setup your dishtv receiver pls replly me at removed@nomail.com tolat charges AED=90 dhs thx its prob in your sat box power spully bye with best reg abbas
PATELRC
zenega cd1004is DISH TV.KUWAIT
kuwait
hsarp72 said:
is it available easily?
can u send me how you chang cap and how u idientify
samwy
DISH TV
Dubai
Hi There,
I am using the dish tv setup box.
it initially start blinking a light orange and green light..and continues the whole time..
the tv screen remains blank.
its not working for almost a month now, but suddendly a day beofre it worked for one complete day and again went off.
I asked here at the local electrical shop if they could fix it, they are not able to do so, i cannot find a dish tv supplier here to fix it.
can i fix it myself???
Can anyone please help me out of this!!!
skeyrock
all aboyt dishtv
dubai
hsarp72 said:
Hello all,
-Hsarp
hello i am from uae if you need more i can make your receiver replly me if you want my number removed - admin
