Jump to content
  • Log in with Facebook Log In with Google      Sign In
  • Create Account
Dish size required to get sundirect signal in south east asia (North Malaysia)
  • Please log in to reply
6 replies to this topic
#1 sshaik
sshaik
  • Member
  • PipPip
  • 14 posts
  • My Satellite Setup: SUNDIRECT DTH only beb...
  • My Location: Malaysia
Posted 25 September 2008 - 02:38 AM
Hi all,
need you guys expert to advice how big dish i suppose to used in order to get sundirect signal from INSAT4B. Currenly I'm using 60cm dish (KU band) but totally unable to received any signal at all. I plaining to get C band but no idea the dish size. As per lyngsat.com, I might able to received the signal unless I used 4ft dish but I'm not sure I able to received all SUNDIRECT channel ? Pls advice
What I have now:
60cm dish
SUNDIRECT STB with simcard
refered to : _http:/www.lyngsat-maps.com/maps/in4b_ecc.html
Pls help...
Edited by HB13DISH, 25 September 2008 - 04:42 AM.
Deactivated Live URL link
#2 srei
srei
    Section Leader
  • Registered
  • PipPipPip
  • 453 posts
  • My Satellite Setup: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card
  • My Location: north west india
Posted 01 October 2008 - 02:03 AM
Theoratically it seems possible with 6 ft dish,I recommend 8 ft solid dish,however,ku reception is always mysterious;sometimes it spills over to those area not covered at all like hotbird being received in India,many other times it has no reception in the area supposedly covered.
I advice not to take the maps for granted.
#3 sshaik
sshaik
  • Member
  • PipPip
  • 14 posts
Posted 06 October 2008 - 05:45 AM
Hi Srei,
recently I bought 4ft dish/FTA STB and C band LNB. Now I able to get the signal using this configuration, but not sure what and how to received usung my SUNDIRECT STB ? Need KU Band LNB ??? or something else, with my current C band/4"/FTA STB, I able to get all Doorshan channels (very good quality)...
#4 Moradabad
Moradabad
    SAT SPECIALIST INDIA
  • Super Moderators
  • PipPipPip
  • 779 posts
  • My Satellite Setup: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna
    Dreambox Dm500S, DM 7025. HD Receiver,Envision,
    Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs
  • My Location: india
Posted 06 October 2008 - 06:21 AM
In SUNSTB you cannot receive any other TPS as in that STB entering TP is not allowed
#5 Analoguesat
    Telstar 1 - 12/7/1962
  • Administrators.
  • PipPipPip
  • 34,046 posts
  • LocationScottish Borders
  • My Satellite Setup: FTA digital satellite from 9 fixed dishes:
    5E/7E/9E/10E/13E
    16E/19E/20E/21.5E/23.5E
    26E/28E/36E/42E/45E
    52.5E/53E/57E
    Echostar IP3000VA, Vu+ Duo (dreadful software) Sky UK.
    Dreambox 7020S, Skybox F3
  • My Location: Scottish Borders
Posted 06 October 2008 - 12:00 PM
Hi Srei,
Is it a solid dish or a mesh dish? If its mesh its not suitable for Ku band,.
Not a member? why not sign up for the forum on your smartphone
If you are on Facebook sign up for the Sats community page at -http://www.facebook....telliteTVforum.
The satellites.co.uk European beam map - http://tinyurl.com/b8ufqgy
The satellites.co.uk 2F UK beam map - http://tinyurl.com/axdvvqe
#6 sshaik
sshaik
  • Member
  • PipPip
  • 14 posts
Posted 09 October 2008 - 12:42 AM
It is 4ft solid dish...pls guide me how to adjust and align with KU band...
#7 srei
srei
    Section Leader
  • Registered
  • PipPipPip
  • 453 posts
Posted 21 October 2008 - 02:32 AM
Bro sshaik,The signal of ku appears to be concentrated to India.Pl check whether you are able to receive ku signals from the satellite with the help of FTA receiver,replace c band LNB with ku LNB and check.If you are able to receive11570 V27500 DD channels,then ku is receivable in your location,otherwise no hope.
