I think as previously requested you need to post a photograph of your dish and setup and actually answer the questions that have been asked of you.
Is it an offset dish or a prime focus dish?
What channels do you wish to receive?
If the profile picture you are displaying is actually your dish i.e. this
then it is no wonder you are unable to receive a signal, the signal path to the LNB is not coming from the Clarke curve. Firstly you need to determine the offset angle of the dish. If that is your dish in your profile then as Puerto Rico is at latitude 18.2 deg North (not dissimilar to the UK), and your dish is a standard 22deg offset then the dish face should be almost vertical. Viewed from where you are in Puerto Rico the top dead centre i.e. the top of the arc for your longitude are 65 deg West or 67 deg West because your latitude and longitude are 18.24914° N, -66.62804° E (66.62804W)
So first find one of those as a starting point
Your dish should look something like this
I am sorry I used to have some diagram pictures to explain all this but they are on an old PC which I am unable to access at the moment
