Hello moonbase what do you think about this card for Novelsat
DekTec DTA-140 DVB-ASI (Coax) DVB-ASI ,Transmit Bit Rate 0…214 Mbit/s
I have never used a DekTec card but I think they are supposed to be a good quality product.
One point to note, what DVB application do you intend to use with the card?
The DekTec cards have the option to be factory enabled to use in house apps (StreamXpress and StreamXpert).
One of these in house apps cannot be enabled after market, I think it might be the StreamXpert app?
You need to check if the card supports whatever third party app you intend to use with the card or if it comes enabled with any in house apps.
I would also check to confirm if the card has drivers for whatever O/S you have on a PC.
Personally, I opted for the TBS 690A card, it works OK with the output from an NS2000 demodulator with TransEdit and DVB Dream using Windows 10.
