new Bosnian package in T2MI
EnoSat
enosat.euweb.cz
Slovakia
This is the output, so astra-sn does not do his job? (Config below)
log.set({ stdout = true, debug = true, syslog = "astra", })
more debugging will be needed to find out at which step astra-sm stops working, or OE2.0 is not suitable for FPGA
Lexzie
TBS 5925 USB-tuner
The Netherlands
What does 'not suitable for FPGA' mean?
It worked on all other T2-MI streams
Is this one different?
EnoSat
enosat.euweb.cz
Slovakia
FPGA - Field programmable gate array
had to be used in DM920 due to the use of two CAM module readers
<4>[    2.221568] register adapter
<4>[    2.225479] fpga init
<4>[    4.267127] fpga prog done
<4>[    4.272158] using fpga version 47
<4>[    4.272467] fp: uart recv error 98
<4>[    4.272853] swd: status is 0, pls check
<4>[    4.272856] swd: cannot init port
Lexzie
TBS 5925 USB-tuner
The Netherlands
That doesn't explain for me how that relates to the Bosnian T2-MI package and why that package is different to other T2-MI package which work on OpenPLi.
How can I debug more?
EnoSat
enosat.euweb.cz
Slovakia
Lexzie
TBS 5925 USB-tuner
The Netherlands
mbas68
33E
poreč
I do not understand what to do.
I guess I have to test it on other hardware or an other image.
hi lexzie, sorry for the trouble, if possible, information on whether you managed to solve the Bosnian channel on 33E, I have dm two and dm920, I tried in every way and nothing .both receivers are multistream, if you succeeded, if possible, the advice is inside the openatv 6.4 image, thank you
If no one has reported success then the answer is no. Be patient. Someone may figure it out in time. If not then you do without unless you buy a receiver that is known to work.
Lexzie
TBS 5925 USB-tuner
The Netherlands
Like Analoguesat said, and as you could have read, I have not succeeded in receiving the Bosnian T2-MI package on 33°E.
Due to persone circumstances I am not able to try out another receiver or other images in the near future.
decmenn
50,1°N 15,4°E
Octagon SF4008, Formuler F4 turbo combo, T-90 (5W-39E), 115 cm offset (75E-43W)
CZ
I have SF4008, OpenATV 6.4 image. Yesterday I got the T2-MI working at 33°E, but the Abertis channels stopped working at 30°W. What should I look for the error? thank you for the advice
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Working on osmini4k and satdreamgr 8!
Unfortunate
screenshot-6-jpg.147960
mikeisyou
Feed Hunter
England
Could someone help me,
I have never been able to scan this on my Octagon SX88+. When using the credentials 11442H 17500 I get no signal and when I scan this aswell as using T2MI PID 4095 I still get no signal and no channels are found when the scan completes. This receiver is capable of scanning this transponder as william-1 has demonstrated. I have the latest firmware installed on the receiver (1.05.96).
One of the things you can do on the Octagon SX88+ is change the symbol rate to 0 and the signal shows up even if the transponder is broadcasting DVB-SX or NS4 which the receiver isn't capable of scanning. When I change the credentials to 11442 H 0 I get a solid signal lock albeit slightly weak (signal quality shows as 33%).
Am I not able to scan this because 33% signal quality is too weak?
Also when I input the T2MI PID to 4095 it reverts back to 8191 after the scan is complete, is this normal on the Octagon SX88+?
I have also tried a factory reset but this fails to resolve the problem.
EnoSat
enosat.euweb.cz
Slovakia
Delete 11442H from the transponder list and try to find the transponder using blindscan
mikeisyou
Feed Hunter
England
I have tried both of these suggestions. Still no luck :(
Is it normal for the Octagon SX88+ to pick up 11442 H on blindscan?
EnoSat
enosat.euweb.cz
Slovakia
Yes, the 11442H is DVB-S2 only
When using a Primo (nearly identical to SX88+) for the T2MI transponders on 14°W I had to blindscan with MTS On and then manually scan the transponder for TV only. My Primo no longer works so I can't check if it works on 33°E.
mikeisyou
Feed Hunter
England
With MTS on and TV only scan selected does not scan in any channels. The only point at which I have signal on 11442 H is when the symbol rate is set to 0. Scanning with a symbol rate set to 0 produces no channels aswell. I think its a problem with my box
I vaguely remembered that sometimes fiddling with the transponder details would suddenly cause a transponder to lock and found this:
But the transponders mentioned are multistream rather than T2MI. Do you have any other receivers that can lock the Bosnia transponder?
