RimaNTSS
Some SAT-related hardware.
N-E from Riga
That I was thinking as well because of the back-frame. Also, the holder for the bottom arm is like Fibo one. But there is a round hole for the bottom feedarm....so, the antenna looks like some kind of old Frankenstein. :D
Manikm909
Small'ish Dish Man
Kent, UK
has this one been posted before...
s-band
Essex
For anyone who wants a tracker for a medium size dish, this would be real bargain. Just add a couple of stepper motors and encoders and find a crane to lift it into position. Approx weight 390kg, overall height 78cm, base dia 45cm:
URL won't embed so copy/paste
https://shop.unigreenscheme.co.uk/engineering/heavy-equipment/siemens-rm-2028669-01-td30-heavy-duty-solar-tracker-mount-
Precision 1.5m motorised setup with Jaeger 1224 H-H motor.
The motor would clean up OK and the feed arm that is possibly siezed on the feed M8 stud can easily be released with a lick from a blowtorch.
The rear mounting ring boss heads seem to be non standard, possibly a custom order from Precision like this?
Or an aftermarket adaptation?
Overpriced in the current market at £450 for "Buy It Now", the pricing is typical of this seller.
At £150 collected it would make a nice motorised setup, could even be tempted myself as a dedicated Ka-Band setup but seller is hungry, no chance of value.
Looks like it might be a 90cm but the included Az/El mount means it will simple to mount on a DiSEqC motor with less (if any at all) bodging required than with the more common 3" Az/El mounts.
Also receiving Atlantic reception so, bargain!
Manikm909
Small'ish Dish Man
Kent, UK
wonder what dish this is ...1.8m something
Joolz
1m Astro 55°E - 63°W
Mobile uplink dish £50 London
Two way Ku from the first picture.
Could be a bargain
Interesting. Is that a folding dish as well? Looks like or so.
tompouce
1.2 M Channel Master motorized+ Gibertini 150 C-band fixed + TBS 5925/6983+ Octagon SF4008
Belgium
Here is a belgian website with some special satellite accessories :
s-band
Essex
Real bargain, someone save it. Anyone want a 1.4m ex RTE SNG dish that's currently blocking my drive?
Got any pictures, Graham?
s-band
Essex
I also have the controller but the cables were cut when it was removed from the van and I can't find any info on the connections. I had it moving using the PSU that's sitting on the frame. Elevation was fine, azimuth OK as far as I could move it without it toppling over. It's quite impressive when it unfolds. There are 2 nice absolute encoders fitted but data on them is elusive. The feed has rotation for skew. It cost peanuts but a fortune to ship, it's a 4 person lift.
