Ses Want Frequency Of Eutelsat
tothbros
Budapest, Hungary
i can also confirm that my sky box has received the epg update, all the effected channels are mapped to 2F PE
mbsnr
Sky+ HD - FTA 43W to 42E
Ireland
Regarding Planet Rock. When this was on Eutelsat I got around 45-55% quality and would suffer dropouts due to rain. I was very pleased it moved to Astra 1N as I get that at 98% quality. But I noticed on Astra 2F PE beam it's only 60%. I'm surprised as I expected a better signal from 2F. I'm in the West of Ireland (Mayo) so perhaps at the edge of the PE beam.....
denis1501
Lazio, Italy
1.25m offset dish for Astra 2 28deg. using Inverto Black Ultra 0.3 quad lnb, Amstrad Sky+ HD, 80cm dish for Hotbird, Sky Italia, Tivùsat, Lenovo Ideapad Z570, 10 mbits broadband.
Sunny Italy
Have you tried adjusting the LNB skew?
mbsnr
Ireland
I have in the past for Eutelsat but it makes very little difference on that box. I just expected 2F to be a stronger signal much like 1N is at present. Perhaps with my setup and the length of the cable run, anything on a TP of 12000 and above doesn't come in as well.
Retired Mod
www.timo.me.uk
It could be the cable, especially if it's not a high quality low loss type and it is quite long. The 2F Euro beam shows it goes well into the Atlantic on the SES official site.
JHMK
110cm: 19E & 13E, 110cm: 28E, 78cm: 1W, 4x Goobay Twin LNB, Faval Mercury HS-100, MicroM45
Oulu, Finland
Finally back at home to check signal levels.
Dish: Triax 110
Previously blindscan found 212 FTA tv channels.
Now i can only receive 115 channels.
Not a huge loss as i use 28e mainly for music channels, but if the north beams and eutelsat would be closed, i couldn't receive anything from 28e then =(
Retired Mod
www.timo.me.uk
I'm afraid the 2A north beam will probably be gone within 6 months and already some of the music channels moved to 2F. Not good.
skomedal
This and that
thule
Any news on the south beam as others and I use it to fine tweak our dishes with weak signals?
Retired Mod
www.timo.me.uk
That'll go too soon. No one is quite sure yet when 2A will leave, but certainly it's days are numbered once 2E and 2G come online.
skomedal
This and that
thule
Thanks timo thought as much, soon only broadband streaming the main option.
Retired Mod
www.timo.me.uk
Temporary transponders on 11954H, 11973V, 12129V, 12402V, 12422H, and 12441V are now all switched off but the temporary transponders in the lower UK spot range still seem to be broadcasting.
the sound 2e will be take 2e service
iandoh
Pärnu. Estonia/Burgas, Bulgaria
1m Mutlibracket (19e, 13e, 10e, 9e, 4.8e) & 1.2m @ 28e
That makes even less channels on 28e for Eastern Europe then. Counting them, that removes 39 channels total
Retired Mod
www.timo.me.uk
Yes, they where just there for a few days to help with the transition from Eutelsat to Astra 2F.
I except the remaining temporary transponders on 10979V, 11082H, 11112H, 11141H, 11156V and 11171H to be switched off soon since all these channels are also now on Astra 2F in the 12.50-12.75 range.
any one confirm tp 11973v move to 1n 12402v and 12610v also
I not get here here
Pietclock
125cm
SE Germany 50°N/11°E
@solly: 12.610V is on the 2F southwest-central Europe beam as are all transponder in Band G (except the SCPC feeds, which are still on E28A I think).
12,402V has been switched off, there is no carrier anymore.
more tp move 12441v to 12663h 2f no signal here
11954h it left from astra 2a
Pietclock
125cm
Flysat list those data transponders on 2F Eurobeam and even E28A steerable. That's wrong , they are all on the 1n PE beam.
