Yea....Ch5 & BBC1 SD London....both slowly have dropped together to 70% Q ...!.....But I'm happy with 70% Q
Yes, Brussels, T90Is that in Belgium on your T-90?
Slightly north of this location (see profile) - no problems 78cm, rain or shine.Location - Savoie, French Alpes 45.6°N 6.8°E. Old Sky 60cm dish - actual size approx 60x70cm.
So far no problems receiving any 28°e channel here. Will check again during heavy rain forecast in next 24 hours.
it is possible!i got low signal
no lock 11221v
it look same eurobird switch to 2e ?
11222H is a little stronger than usual (about +1dB here to 6.2dB ) but I'm still getting it on an 80cm dish in Helsinki... no chance of getting a decent 2E signal like that. (Strongest 2E Europe 11778H is currently 1.5dB but gets stronger in the afternoons)it is possible!
11222 here + 2dB!
Edit: Looking at my readings from the last couple of days 11222H has been stronger for all the past readings compared to last month. Could this have anything to do with 28B leaving? Surely it wasn't on 28B and has switched back to 28A??
