Channel Master 1.0m v 1.2m
Riverblue
Near Brighton
After getting all the bits I needed together I have finally got round to setting up my Channel Master 1.2m. It is on a fixed azel mount on a 3" pole NPRM placed on the ground and will be used solely for 7W. I have not permanently fixed the NPRM as I am looking for the best place to site it out of view, when I have I will fix through the NPRM into the concrete path on one side of my house.
I am using an Inverto black ultra single lnb on the 1.2m, my motorised 1.0m also has an ibu, but it is a quad. I set up a temporary lead for the 1.2 to see what results I was getting off of 7W. Conditions were clear, sunny and still. My Dr F15 was showing 11.0 / 11.1dB on Qatar TV HD on 10719 V 27500 with the 1.2m. When I swapped over to the 1.0m I was getting 9.0/9.1 dB on the same program/transponder. I might be able to eek out a bit more when I do the final install and fix everything down more securely. :) Overall I am very happy with the improvement in signal reception, I can see it will be worth the effort :D I hope it will be enough to counter the effects of rainy/cloudy weather.
1.2m dish
1.0m dish
Searching other tp's the increases were similar with the 1.2m dish. Pictures of the final setup will follow.
Very good indeed - I hope in due course you'll let us know what you can receive now that you couldn't before.
Riverblue
Near Brighton
Will do, I intend to do a full blindscan of 7W with the Dr F15 with both dishes when I am finished. It will be interesting to see what, if any, differences there are with the increase in signal reception. I shall, in due course, do a comparison with my other boxes as well. :)
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Good results! However, it should be like that, cuz you changed 1m dish to 1,2m. No surprise :rolleyes:
Riverblue
Near Brighton
Definitely not a 'surprise', :eek: I knew I would get better reception with the larger dish. I just thought someone would like to know exactly what difference you would get on a like for like basis. :p
Someone did. It was I!
RimaNTSS
N-E from Riga
OK, You where using different LNBs on different dishes, and those dishes where, most likely, pointed differently to 7*W. You also did measurements on only one frequency. And after all that you can tell exact difference between performance of 1m and 1,2m dishes?! And what is exact difference than? Can you give answer in %%, dB or "times"? I do not think so. Just kidding. :-buttkick
Riverblue
Near Brighton
No, it wasn't a "definitive test", did I state that it was? and I could've uploaded screenshots of the 80 or so tp's on this bird or hundreds of programmes to show more evidence of the differences, state BER, S/N ratio etc., but I deemed it unnecessary. :rolleyes: The object was to let people know what I was getting with these two setups. Both dishes have been setup with a professional meter, I'm confident that there isn't any more you could squeeze out of the 1.0m dish and it tracks the arc as near as perfect, but, as I said, I might be able to get a bit more out of the 1.2! :)
RimaNTSS
N-E from Riga
it tracks the arc perfectly
Comon, nothing and nobody is perfect! And, moreover, did you check whether LNBs were located in focuses of your antennas?
Sorry for all that. I see there is difference between 1m and 1,2m dishes , and there is consequent difference in their performance.
However, I personally do not know what is exact difference in performance of those dishes! Of course, it is possible to calculate difference between surfaces, but that will not be difference in performance. Hope you understand my worries.
Never mind, forget everything after "Good morning". ;)
Archive-8
Just scanned 7w on my 1.25 gibertini.
[SATTYPE]
1=3530
2=7.0W Ku-Band H+V
3=0
4=9750
5=10600
6=11700
[DVB]
0=54
1=10727,H,27500,56,1,|9.1 dB
2=10757,V,27500,56,1,|9.4 dB
3=10777,H,27500,56,1,|9.2 dB
4=10796,V,27500,56,1,|9.5 dB
5=10815,H,27500,56,1,|9.2 dB
6=10834,V,27500,23,150,|9.5 dB
7=10853,H,27500,23,150,|9.6 dB
8=10873,V,27500,34,1,|7.8 dB
9=10892,H,27500,34,1,|9.7 dB
10=10922,V,27500,34,1,|8.2 dB
11=10930,H,27500,56,1,|8.4 dB
12=11219,H,27500,56,1,|8.7 dB
13=11227,V,27500,56,1,|9.5 dB
14=11257,H,27500,56,1,|9.1 dB
15=11277,V,27500,23,150,|9.3 dB
16=11296,H,27500,34,1,|9 dB
17=11315,V,27500,56,1,|8.8 dB
18=11334,H,27500,56,1,|6.7 dB
19=11353,V,27500,56,1,|9.8 dB
20=11373,H,27500,23,150,|8.9 dB
21=11392,V,27500,34,1,|9.4 dB
22=11411,H,27500,23,150,|9.3 dB
23=11430,V,27500,56,1,|9.7 dB
24=11449,H,27500,56,1,|6.7 dB
25=11488,H,27500,56,1,|9.2 dB
26=11526,H,27500,34,1,|8.4 dB
27=11564,H,27500,56,1,|9.6 dB
28=11603,H,27500,34,1,|9 dB
29=11641,H,27500,56,1,|-10 dB
30=11661,V,27500,12,1,|2.9 dB
31=11679,H,27500,56,1,|8.4 dB
32=11901,V,27500,56,1,|7 dB
33=11939,V,27500,34,1,|7.8 dB
34=12054,V,27500,56,1,|6.9 dB
35=12111,H,27500,34,1,|9.8 dB
36=12131,V,27500,56,1,|7.3 dB
37=12149,H,27500,34,1,|5.1 dB
38=12169,V,27500,56,1,|10.1 dB
39=12188,H,27500,56,21,|9.8 dB
40=12207,V,27500,34,1,|8 dB
41=12227,H,27500,34,1,|5.1 dB
42=12245,V,27500,23,150,|10.2 dB
43=12265,H,27500,23,150,|9.8 dB
44=12284,V,27500,34,1,|7.2 dB
45=12322,V,27500,23,150,|10.7 dB
46=12342,H,27500,56,1,|9.8 dB
47=12361,V,27500,34,1,|10.3 dB
48=12380,H,27500,56,1,|10 dB
49=12399,V,27500,56,1,|9.5 dB
50=12418,H,27500,34,1,|9.9 dB
51=12437,V,27500,56,1,|10.2 dB
52=12468,H,27500,23,150,|9.6 dB
53=12476,V,27500,23,150,|4 dB
54=12627,V,2220,12,1,|10.7 dB
RimaNTSS
N-E from Riga
Archive-8
Good list! But you are not getting Riverblue's mentioned frequency
at all, and you are living just couple of hundreds kilometers from each other.
No I seem to be getting it on 10719 v 22000 3/4 QPSK S2
Riverblue
Near Brighton
My mistake Chris, it is 22000, not as I stated :-dohgot mixed up with all the 27500's on this bird!
RimaNTSS
N-E from Riga
Sorry, I do not understand that :(
Can you receive Qatar TV HD on 10719 V 27500. If you can what is signal level?
That is frequency Riverblue made comparison of his 1m and 1,2m antennas.
Edit: I see, simultaneous postings.... S/R is 22000
Riverblue
Near Brighton
Just checked my 1.0m against your list Chris and I'm getting some variations.
12149 V 27500 5.9dB > 5.1 for you
12227 H 27500 6.2dB > 5.1 for you
12476 V 27500 8.7 > 4.0 for you
All of the other readings are bigger on your list, generally by 1/1.5dB but about 8 where there is only 0.2/0.3 difference!
Archive-8
My tbs card is not as good as it used to be. I do get the 10719 v but it's on a tm5302 that gives an 82% signal.
I have just scanned again rolling back the driver.
[SATTYPE]
1=3530
2=7.0W Ku-Band H+V
3=0
4=9750
5=10600
6=11700
[DVB]
0=54
1=10727,H,27500,56,1,|8.9 dB
2=10757,V,27500,56,1,|8.8 dB
3=10777,H,27500,56,1,|8.6 dB
4=10796,V,27500,56,1,|9.1 dB
5=10815,H,27500,56,1,|9 dB
6=10834,V,27500,23,150,|9.2 dB
7=10853,H,27500,23,150,|9.3 dB
8=10873,V,27500,34,1,|7.7 dB
9=10892,H,27500,34,1,|9.4 dB
10=10922,V,27500,34,1,|7.9 dB
11=10930,H,27500,56,1,|8.3 dB
12=11219,H,27500,56,1,|8.5 dB
13=11227,V,27500,56,1,|9 dB
14=11257,H,27500,56,1,|8.7 dB
15=11277,V,27500,23,150,|9 dB
16=11296,H,27500,34,1,|8.7 dB
17=11315,V,27500,56,1,|8.5 dB
18=11334,H,27500,56,1,|6.5 dB
19=11353,V,27500,56,1,|9.4 dB
20=11373,H,27500,23,150,|8.5 dB
21=11392,V,27500,34,1,|9.1 dB
22=11411,H,27500,23,150,|9.1 dB
23=11430,V,27500,56,1,|9.5 dB
25=11488,H,27500,56,1,|8.8 dB
26=11526,H,27500,34,1,|8.1 dB
27=11564,H,27500,56,1,|9.3 dB
28=11603,H,27500,34,1,|8.8 dB
29=11641,H,27500,56,1,|8.5 dB
30=11661,V,27500,12,1,|3 dB
31=11679,H,27500,56,1,|8 dB
32=11900,V,27500,56,1,|6.3 dB
33=11920,H,27500,56,1,|5.9 dB
34=11939,V,27500,34,1,|7.6 dB
35=12054,V,27500,56,1,|7 dB
36=12111,H,27500,34,1,|9.4 dB
37=12131,V,27500,56,1,|7.5 dB
38=12149,H,27500,34,1,|5.7 dB
39=12169,V,27500,56,1,|9.6 dB
40=12207,V,27500,34,1,|8.1 dB
41=12226,H,27500,34,1,|5.8 dB
42=12245,V,27500,23,150,|9.8 dB
43=12265,H,27500,23,150,|9.5 dB
44=12284,V,27500,34,1,|7.5 dB
45=12322,V,27500,23,150,|10.4 dB
46=12342,H,27500,56,1,|9.3 dB
47=12361,V,27500,34,1,|10 dB
48=12380,H,27500,56,1,|9.5 dB
49=12399,V,27500,56,1,|9.1 dB
50=12418,H,27500,34,1,|9.4 dB
51=12437,V,27500,56,1,|9.4 dB
52=12468,H,27500,23,150,|9.4 dB
53=12476,V,27500,23,150,|2.5 dB
54=12627,V,2222,12,1,|9.7 dB
Chris, what software are you using to scan this to get the list?
sonnetpete
wordpress.com
Normandy, France
Just to chip in with my result on Qatar HD....this using the Gibi 1M in the multisat....
Edit : Same TP on my 1.2M motorised, 10.3Db
