- Jan 7, 2009
- Age
- 58
- Some SAT-related hardware.
- N-E from Riga
OK, here I would like to open discussion on finding focal point of offset antenna and proper direction of LNB placed ind that point. I see the need for this discussion cuz not every sat-user knows exact location of this mysterious point in sat system. Not everybody ever checked position of LNB , how it is located and where is pointing towards surface of antenna. I also think that not all antenna's producers made feedarms perfect to hold LNB in right point and direct them to the right direction. We all can check that on real dishes we have.
I do not think I can start from very beginning of theory, but would like to do job step-by-step.
So, first step would be to check weather dish is perfect shape. If it is warped than does not make sense to continue this dialog.
Check warpage is easy- just string (put threads) your dish vertically and horizontally. And only if vertical and horizontal threads are touching each other you can continue with finding focal point of antenna.
Be honest to yourself, even 1mm gap between strings is not good and make no sense to continue reading this thread. It is also advisable, if possible, to find out offset angle of your antenna provided by manufacturer, and also to get digital protractor (could also be analog) for future measurements.
Attaching picture of antenna I have with existing gap. This antenna will still work, but will newer bring you maximum result.
TBC
TBC
