Astra 2G: Scandinavia & Baltics Reports
Reports by Region, please, once she lights up.
General Operational chat here
archive10
Quick update (after alleged move to 2G for some transponders):
Overcast, heavy rain earlier in the day (moist air).
Eveythng still working fine here north of Copenhagen/DK on CM180/BUQuattro:
BBC etc as usual, CBS channels booming in, ITV going very well.
No significant change in user experience after 2G.
We need some kind of tracker on you....
popolon
south west of Finland
Teleste 5m,invacom quad (28.2E), invacom quattro (26.0E). Triax multiswitch (1in, 8 out)
-TT 1600 PCI. Prof 3701 PCI.
-DR HD F15
-Ariva ferguson A120
Aerial 3m dish (7W-28.5E) + motor+ invacom quad.
-Ariva ferguson A220.
Finland
It seems 2G euro beam is too strong in Finland for UK spot signal...so I hate already this 2G eurobeam. Before 2G, there was really no strong signals at low band 10700-11700 except 2C affecting 2F UK spot. Anyway 2E is not affected, so 2E UK spot signal at least stays...
popolon
-DR HD F15
Finland
2G UK 10964H was fine yesterday about 11 hours, between 12:00-23:00... againsts 2F UK 24h receptions for that same channel...it seems the reception goes worser now (prev day 24h cycle was much higher signal)..
Fredrik M
Gibertini 125 dish, Inverto Black Ultra single aimed at 28.2 E, built in Philips TV receiver
Triax 110 aimed at Telstar 12 (15 W)
Landvetter (15 km E of Gothenburg), Sweden
The signal levels on UK beam channels dropped after the switchover and I had some pixelation on 11023H (BBC Four HD etc.) yesterday. However, it seems to be improving for us here in South western Sweden. The weather was really bad on wednesday so it is a little difficult to compare one day to another this week. Astra 2F was always much stronger than 2E here. On wednesday, 2G seemed weeker than even 2E, now it is the other way around. Maybe the nill-line over Denmark is moving westward somewhat for 2G. Such move would be beneficial for us in Gothenburg at the cost of viewers in e.g. western Norway.
cazhh
Elmshorn, Schleswig-Holstein
yes, moving westward. But bot 2E and 2G. The nulls are now almost touching Hamburg. But i hope it's the normal summer low
Retired Mod
www.timo.me.uk
Over on the Finnish forum member huve is reporting good signal levels on his Helsinki 110cm balcony setup for the 2G Europe beam on the ex-28A transponders. Not as strong as the old 2A/2B North beam but much better than Eutelsat 28A. This means I should be able to pick it up on my 85cm setup too. Will confirm levels when I get back to Finland.
Kveys
Southern Finland
Can confirm huve´s notes absolutely. Clearly stronger than 28A earlier (2G Europe beam).
Retired Mod
www.timo.me.uk
Great, thanks. I could get 28A pretty well, so this is encouraging.
What are your signal levels like for these temporary transponders:
11.464H 22.0 5/6 QPSK DVB-S
11.479V 23.0 8/9 QPSK DVB-S2
11.509V 22.0 5/6 QPSK DVB-S
My friend in Odense, Denmark lost ITVs on 11053H as they are on UK beam (Selfsat antenna). Or did they move from somewhere?
Retired Mod
www.timo.me.uk
Moved from 2F UK to 2G UK but same frequency.
Hm but he used to receive ITV2,3,4 HD from somewhere on his Selfsat, so it had to be on another frequency (European beam)... but anyway... he can't get that on his tiny dish :)
Retired Mod
www.timo.me.uk
ITV2/3/4 HD versions moved from 11.758H 2E Europe a few weeks ago to UK spots on ITV's own transponders.
Kveys
Southern Finland
14.5 dB, 15.6 dB and 16.5 dB.
4wd
Getting the picture
5 W, 9-13-19-28 E
2G UK: after some initial hope with strong levels on 1st day, now beyond stable reception with current dish size, similar level cycles as 2F UK.
2G EU: excellent, better levels than anything seen from E28A. So if everything else fails, I can watch Paver Shoes 24\24 lol+++
popolon
-DR HD F15
Finland
Channel5 now receivable 24h after moving dish ( was maybe off towards 28.3 after last move experiment)...but no heavy rain margin...
4wd
Getting the picture
5 W, 9-13-19-28 E
2g uk much improved levels yesterday evening (sd ok) and today (sd & hd ok).
