1.5 Precision dish install
Archived-1
Persona non grata
uk
Martin
why didn't use only one latitude adjustment rod like Channel Master did for their mounts
Hi samoloko funny you should say that I was wondering why CM did not use two like me who's right ? who's wrong ?.
samoloko
1.8 PFA
EU
with one pcs you can get easy user friendly and symetrical adjustment
Archived-1
Persona non grata
uk
My thinking is when there's a big dish on this mount it will pull it more accurately pulling from two points rather than one;), you can get a little twist pulling from one bolt ;), one bolt is fine for this small dish but your better with two with larger dishes, using two is only a plus not a negative :)
Archived-1
Persona non grata
uk
Hi. i popped out and had an hour on the actuator, its going to be a bit of trial and error for the positioning of it but ive started at this point, ive only tack welded the bits on, I cant see me getting it right the first time. i will put some power to it tomorrow and test it :)
DSCN0366.JPG DSCN0367.JPG DSCN0368.JPG DSCN0369.JPG DSCN0370.JPG DSCN0371.JPG DSCN0372.JPG DSCN0373.JPG DSCN0374.JPG
archive10
A Precision prime focus dish is a mans satellite dish, them offset focus dishes are for pussy whipped gimps. Forget the bollox about the feed and support arms blocking out the signal, just get a bigger prime focus. Its a no contest, the offset focus dish did not even get to the starting line.
The day I have to consider erecting an offset focus dish for my own use will be the day I give up with satellite.
Lol Dave that's one way of putting it:D, yes you gimps get a mans dish :p:D:-lol
Well...
Talking of a man's dish.
Check the Prodelin 1241 in this picture (from gdsatcom.com)... quite a feed-support arm, isn't it? :D
I think 0.8 f/D offsets look very purposeful too, more than 0.6 f/D ones... and, some might say, perhaps even more man'ish than the PF's?
(...If only I had a Prodelin 1241... hey, wait - I do in fact have one! I just need somewhere I can, erhm, erect the dish...)
Archived-1
Persona non grata
uk
(...If only I had a Prodelin 1241... hey, wait - I do in fact have one! I just need a polar mount set of arms, my wife wont let me install it so somewhere I can, erhm, erect the dish...)
They you go st1 fixed it for you :D
archive10
Much obliged :cool:
Meanwhile, I might go play with the H2H mounted CM240 at work - I've been told I can pretty much play with as I like as we don't really use it that much these days...
But of course - it's for pussy whipped gimps, so maybe I should stick to my Toroidal T55 pointing at everything at the same time... :D
Archived-1
Persona non grata
uk
I am in the pussy whipped gimp club more than most of us I have 4 and 2 man dishes :-lol
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
At the risk of repeating myself ...again..
All PFs are female whereas Offsets are male dishes ....so no wonder we tend to get all loved up about PFs is it ?
'Prime' example ...err pardon the pun ..
Who amongst us chaps dont get a er*****n ....standing next to the Lovell ... ?
(I call her Stella)
Or is that just me ...
lol...
My wife left me years ago ...
I often wonder why...
:D
I choose not to worry tho' ...some men love their cars or boats ...so
does this make me a freak...
Good stuff this Guinness...
Hic
samoloko
1.8 PFA
EU
Meanwhile, I might go play with the H2H mounted CM240 at work - I've been told I can pretty much play with as I like as we don't really use it that much these days... .
can you do a few shots from mount
Archived-1
Persona non grata
uk
Well ive nailed it first time smooth movement:), very pleased with this, on to painting her and lining her up:).
DSCN0386.JPG DSCN0387.JPG DSCN0388.JPG DSCN0389.JPG DSCN0391.JPG DSCN0393.JPG DSCN0394.JPG DSCN0395.JPG DSCN0396.JPG DSCN0398.JPG
Archived-1
Persona non grata
uk
It's looking really good :cool: do you do custom orders? For the mounts?
Thanks Chris :),
I am seriously thinking about making mounts as a second income and see how it goes, I have plans in mind for a 12/12 workshop at the top of the garden and going to kit it out with all the proper gear,
First part of this project is already bought the window in this picture, this is where the workshop will be, I need to ebay a few more windows :), so yes pal in the future :).
Retired human
Can you take a video of the movement? Just to see how the PM and the jack operate.
Archived-1
Persona non grata
uk
I can do Alex the actuator more/less stays where it is, unlike on the 1.2 it sticks up/down at ends of the arc, wait while I get it setup and I will post a vid up.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
