further to my original question, rather than feed hunting and just for a standard box, is the 5502 HD better than the 5402 HD mK3 when using 2 Lnbs on 1 dish? thanx
William,
What are the main differences for feed hunting between the TM-5302 and the TM-5502 apart from the case size and CI with the TM-5502?
Rgds
William,
Is there a fat version of the TM-5302, I have seen references to the slim version of the TM-5302 but what about a fat version (non slim) and how does the fat TM-5302 compare to a TM-5502?
Rgds
Yes there is I have all 3 versions The fat version of the TM5302HD performs as well as the TM5502HD CI+.
William,
Thank you for your feedback.
It seems that the fat version of the TM-5302 does not have the blind scan issue of the slim version where it gets stuck, is that correct?
Rgds
I tried that William, they denied it was a problem, and said it should work, got nowhere with them.Support for these receivers while very good unless this is picked up in the early stages after release & reported to TM there is not much that can be done now except to use 2 receivers,
As the software people rarely go back to a receiver after 2 to 3 years,
You could contact TM to tell them of your discovery & maybe they can help,
Telephone
+44 (0)20 8884 0701
Perhaps you'll have more luck than me!Many thanks William, i'll contact Technomate.
Till yet I haven't find any feeds. I am not able to find any signal for feed frequency. All other is okay.today there was a live feed on asiasat 5 3828/7120/H. I had tuned for strongest tp of asiasat 5 after that there was no signal for this feed. Trying for various feeds for last 6 days.Nothing wrong with your open box for finding feeds.
