Installing Dishes In Spain for 2E Chit-Chat
Looking cloudy for you ATM Brian. Chance of rain?
Signal for last 24 hours...
Archive4
Quick heads up for anyone round here hunting the ITV HD versions.
Although it was updated on Flysat on the 11/8/2016, I only found out by accident the other day, ITV HD Anglia East has moved to 11068V from 11097 V and is a lot easier catch in the fringe areas
Archive4
Found this on my travels today, looks lovely! Did note, no longer used as motorised , wonder what that actuator could drive , look closely , it is no longer being used!
Is it a CM 2.4m?
Archive4
Don´t know, did not get close enough to see any markings on it , but it does look like it could be. If it is , it´s the first one I´ve seen in the flesh ( so to speak )
That jack looks powerful as well , and not being used. Wonder if I could remove the jack and lock the dish in place without it ?
Have to go back there in the next few days as they are having problems with a Foxsat HD bos I moved to the bedroom to make room for the new Humax Freesat box.
Well if you need help to take it down give me a call.
Archive4
I´d love to take the dish down, but they are still using it as a fixed dish, so not an option.
Just thinking could I " borrow " the actuator without causing problems.
That said, I do have a second hand Fam 1.8 I could put in its place, or even the spare new Laminas I have.
Need to check it out closely next time I´m there :D
You need to have a chat with them see if they would be happy for a trade even if it costs you a bit. That dish would be great for C band. Mouth watering here.
Archive4
Think it is a CM , found some photos of one here , looks the same
A fresh start with Channel Master 240 | DRHANS Online
Did notice the lnb if failing or the dish is out of alignment as was only getting about 9dBm on BBC 1 South. That said it was Wednesday and may have been around the 11:30 mark I checked it. Solar outage may have been affecting the signal.
As an aside, what is it worth , roughly , assume good condition?
No idea what it is worth. Offset version is about 3k new.
Blimey, didn't realise @drhans was still publishing reviews. Nice to see them...have been reading a lot of them in the noughties.
