Advice Needed TBS 5925
blademedia
Sky
Hello, going to order the above tomorrow, need advise on what I need to install, any software I need to buy thanks
Useful applications that you need for tbs card or tuner usb are: EBS Pro and dvb-s players with license (DVB Dream,ProDVB,DVBViewer)to have access to all functions.We have great luck that Crazyscan is free and that thanks to @CrazyCat.The rest of the applications you'll discover yourself along the way.
TVDXer
7.5-ft C-band; 1.2m Channel Master on HH120; MicroHD; Amiko A3; TBS 5980; TBS 6983
Ottawa, Canada
SmartDVB is a good free viewing program. I use it with a TBS6983.
Unfortunately, EBSPro has ceased selling licences.
TVDXer
Ottawa, Canada
Really? Why?
It was reported in Rick's Wildfeeds forum (where the author of EBSPro used to post a lot). Apparently the author announced this in a Tweet. The 'Donate' button on his website is disabled, so there's no way to pay for a licence at the moment (and he hasn't made it free!). The wording of the Tweet could be interpreted that it will come back in the future.
Sent from my SGH-I747M using Tapatalk
blademedia
Sky
Thanks for advice. will have a good read up not good with things like this will learn :)
Nice little receiver :)
I say you wait a bit until appears excellent 5927!
What does 5927 do that 5925 does not?
Keeping well up with the game, then: Probably ahead of the game, if the truth be known.
blademedia
Sky
I need two/three boxes so it no problem, its not out while end of year, will give me time to get used to using them:)
Yes mine is hot too after mild use. Probably why they fail prematurely
blademedia
Sky
Totally new to using cards Jack, for the sake of £10 or less its worth keeping it cool, maybe look for one with usb fan,
I couldn't get a picture to start with, swapped to Elicard codecs and its ok, any advice on better codecs to download please, one that's working is 2003,
Nice to get a screen shot without messing with camera, laptop appears to be handling HD ok about 50% usage don't know how it will cope with more power hungry stuff.
Lots to learn but first impressions I love it :)
blademedia
Sky
Downloaded later version with updated codec. CPU appears to be running lower with HD channels than older version, I will have to set newsgroups up see what software I can find :D
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
HEVC UHD 4K
I have same 5925 card, should it be able to view a feed in the above format?
pontiend
Contibruter
south yorkshire
Blade.Screenshot is pretty good I used it a long time.
I find that the snipping tool is quicker.Also most of the time you do not have to resize the snips.
To find it click Start, then all programs,Then Accessories.It is half way down the list.
If you use it often like I do right click on it choose 'Pin to task bar'.Works in W7. Don't know about W10. Appoligies if you already know this.Don't want to be telling Granny how to suck eggs.:)
Works in Win 10 too.
