Old 26-10-2005   #1
Problem with full x 3 on astra
I have two ways to receive fullx. First solution is my neotion501 with embedded neotion cam. Second is Technomate tm5500cisuper with Zeta blue cam.
With both systems I can decode fullx 1 and 2 reliably. With full x 3 on astra I get the channel unscrambled for a few seconds, mayby a minute or so if I am lucky, and then the picture reverts bit by bit to scrambled. The signal shows 75% strength and 45% quality on both receivers. Anyone else have this problem with full x3?
cableman is offline   Reply With Quote
Old 27-12-2005   #2
I assume you mean full-x 3M. On Astra fx3 and fx3M are available. With fx3M I have no problems but fx3 will not decode properly: sometimes no sound or picture breaking up.Also the cam (blue zeta) only decodes when in the lower or (2nd?) slot. If you dont have fx 3M re-scan, it should come in next to fx3. Good luck.
mikk is offline   Reply With Quote
astra, problem
Similar Threads
ASTRA 2D BBC & ITV RECEPTION Expat Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 591 11-06-2009 09:25 AM
Astra 2D + Astra 1 + Hotbird....? xband Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 4 09-11-2003 08:04 PM
Russian Hour on Astra satellites net1 Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 1 14-10-2003 08:03 PM
Astra to launch 1KR in 2005 net1 Transponders & channels 0 09-09-2003 06:26 PM
is this a diseqc problem doggy DISH SETUP: Single sat, Multi-Sat & Motorised systems 14 05-09-2003 02:44 AM
