Thread Tools Display Modes
Old 19-05-2008   #26
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card
He battled for 3 days against the Tux and won! Hurray!!
Just looked at the Dreambox 900
It has embedded Irdeto CAM
If you bought Viaccess card then it will not work
If it is Irdeto, then just insert the card with the chip down.
HB13DISH is offline   Reply With Quote
Old 21-05-2008   #27
My System: Satellite only, no computer
1-Irdeto Embedded
2-CAm slot Embedded
It was working perfectly allright and after fresh scann its gone.
rizwanrk is offline   Reply With Quote
Old 21-05-2008   #28
Originally Posted by rizwanrk View Post
1-Irdeto Embedded
2-CAm slot Embedded
You should have mentioned this before.
Scanning shouldn't cause any problem.
Try to shutdown the box, pull the power cord, wait few minutes, plug it in, switch on and see what happens.
The Following User Says Thank You to HB13DISH For This Useful Post:
rizwanrk (26-05-2008)
Old 26-05-2008   #29
System info
Originally Posted by HB13DISH View Post
1 - Which encryption option does it have (Viaccess or Irdeto)?
2 - Is there a CAM Slot/slots in your receiver (embedded or CI)?
3 - Do you have an Irdeto or Viaccess CAM (depending on Q1)?
4 - If your receiver is FTA, then you can't.
Irdeto embedded
• 6000 channels memory
• Input Frequency
• 950-2150 Mhz
• Support EPG
• Multilanguage function
• Easy graphic menu
• Teletext supported by VBI
• Digital Tuner with loop-through
• Last channel memory
• Multi-search
• Easy & fast software upgrade through RS 232C Port
• MPEG-2 Main Profile at main level
• Dolby Digital Audio
• Supports Game
• DiSEqC1.0 and DiSEqC1.2/1.3 cintrol compatible
• Tuner sharp
• 2 MB flash
• STI CPU
Old 26-05-2008   #30
If you still have problems with your card, try deleting all the channels from the channels list for this package (Free-XTV, Xdream, etc.) and then rescan their TP frequency.
Old 27-05-2008   #31
Delete will not delete the channel permanently????
Old 27-05-2008   #32
My receiver is XDream 900 not Dreambox 900
Old 27-05-2008   #33
I don't think so.
Test this first on a channel that is not impotrtant and note it's frequency, Pol, SR, FEC delete it and then rescan.
Old 31-05-2008   #34
prince27's Avatar
My System: TOPVISION
where from we get that in dahran?
prince27 is offline   Reply With Quote
Forum Jump
