Aljazeera card 1-8
Discussion on the Al Jazeera - Middle East satellite TV subscription packages.
Old 4 Weeks Ago   #1
My System: technomate 1500 strong 4375 pace digi box triax 1.1, triax 88cm
Aljazeera card 1-8
Guys a question,
i have just bought an aljazeera 1-8 card with an irdetto 2 cam, i have started using it in a teck 6800, i thought that was the right thing, i suppose it was, a while later i was using a teck 1500 and out of curiousity i slipped the card in the card slot of the 1500 and all the channels started working straight away, do you think it will be alright to leave the card in the 1500 slot, as far as the cam and 6800 is concerned every 20 mins to 30 mins a little glitch pixelation etc! comes on the screen for a second, slightly irritating. I have read up about hd boxes and from all acounts sometimes they can come up with little problems due to the new technology, mind one thing, the dish is inside the back bedroom.
johnwilliam1 is offline   Reply With Quote
Old 4 Weeks Ago   #2
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
the card should work fine in the card slot of the 6800, did you try that ?
if all the channels are working then it will be fine to leave in the card slot, its only when 1-4 channels only work that it needs a cam to work.
since when did aljazeera sport use irdeto 2 thought the new hotbird cards were viacess 3?
Old 4 Weeks Ago   #3
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4
They're both. When I ordered one they said only Irdeto were available. Later they rang me and asked if I'd have a Viaccess because the Irdeto stock had run out.
Huevos is offline   Reply With Quote
Old 4 Weeks Ago   #4
yes i have tried the card in the 6800 slot it says invalid card, yet the strange thing is it works great in the teck 1500 card slot, i have just had it in there for 2 hours and no problems at all. I think i am going to get in touch with the guy who i bought the cam from, i also put the cam in an 0ld echostar 3000 with the card and i was surprised it worked in there but again after about 20 mins there was pixilation for a second on the tv.
Old 4 Weeks Ago   #5
My System: MOTORISED
I Have Got A Aljazeera card 1-8 Irdeto. i have a tm9100s But My Reciever Will Not Read It.
DAVE22 is offline   Reply With Quote
Old 4 Weeks Ago   #6
My System: Sky; Raven 90 multi-LNB 1W, 7E, 9E, 13E 16E, 19E; 1m Orbital dish on Moteck SG2100 motor; Technomate 1500, Phoenix Apollo and Kathrein (analogue) etc etc Receivers
I think (not sure) that the Technomate 6800 has to be 'patched' to turn it into multicrypt to read cards of different encryptions; don't know if this is also the case with the 9100.
bigtee is offline   Reply With Quote
Old 4 Weeks Ago   #7
i would say it works in the 6800 and also in the echostar 3000, but it has this irritaing thing of evey 20 mins or so of pixilation for a second or so, in the tek1500 card slot its great and thats where i am keeping it
Old 4 Weeks Ago   #8
My System: technomate 6800 +diablo - im motorised dish
well in my tm 6800 running 6.79p apr 17 2009 patch
tha irdeto card activtes and runs 100% no problems.????
try this patch 6.79
robbiemcd is offline   Reply With Quote
Old 4 Weeks Ago   #9
Nolia's Avatar
My System: Moterk 2100a motor on 80cm dish,16'E-18'W Manhattan XT-CM receiver. Fixed Sky dish 28'2E
I have the Irdeto one on Hotbird. It works fine on my Manhattan XT-CM without cam. I tried a cam too and it was okay. I do get a occasional NO IRDETO access msg but once I select JSC+8 it works well. I suppose it could be a update signal
Nolia is offline   Reply With Quote
Old 4 Weeks Ago   #10
yes on the teck 1500 i got a scrambled logo last night, oh no i said to myself, but it soon disapeared, probably it will work similar to yours in the manhatton. I got in touch with the guy at totalsat and he told me to send the cam straight back and they will replace it with another, so i think thats going to be okay
Old 4 Weeks Ago   #11
Nolia's Avatar
yeah possibly. well at least totalsat r ok not FALCONSAT.
Old 2 Weeks Ago   #12
issedin's Avatar
My System: i have 90cm dish from triax with +4 lnb
hej guys. i have a VACI-5350 HUMAX RECEIVER. It`s actually good and am using it now and am receiving hotbird and astra with no problem. i would like to buy the new aljazeera card to view sport. is this receiver compatible with this card. if the answer is no what about ..HYRO 5010S RECEIVER with one card slot will it work with the card.... thanks issa sweden.
issedin is offline   Reply With Quote
Old 2 Weeks Ago   #13
Al Jazeera Sports uses Viaccess 3.0 or Irdeto. You will need to check your receiver is compatible with whichever one of these you purchase.
Old 1 Week Ago   #14
My System: GOLDEN INTER STAR 8005 S
merci johnwilliam1 jai chercher sur key jsc+
elhaddani is offline   Reply With Quote
aljazeera, card
