echostar ad3000IPVA and french analouge channels on 5w - sound problem | |
| | #26 | ||
| Member Join Date: 08-12-2007 Location: smallest country on the Iberian peninsula
My System: echostar ad3000ipva and LIDL SL65 on a Wavefrontier t55. Long live analogue sparkles. | Don't worry - Found out how to do it ![]() I scanned and it found TV8 Mont Blanc. Also, I have added the TP with Canel Algerie. However, it found a couple of encrtpted channels that I won't watch. Is there a way to remove specific channels on a TP? (I am starting to get the hang of this and its starting to be fun!) Last edited by qwerty14; 09-12-2007 at 06:25 PM. | ||
| | #27 | ||
My System: echostar ad3000ipva and LIDL SL65 on a Wavefrontier t55. Long live analogue sparkles. | Answer found: Menu / Edit / Edit TV channels / select channel and press red button twice. | ||
| | #28 | |||
My System: Sky UK family pack. FTA analogue & digital satellite from 5 fixed dishes (4.6E/5E/13E/16E/19E/23E/28E) Pace MSS100, Echostar IP3000VA (with dragon cam), Coship CDVB 2300A, Fortecstar Lifetime Ultra, Technomate TM-1000D, Dreambox 7020S, 2250kb ![]() The last noble sat warrior to fly the olden flag of Analogue | yah. The Echostar IP3000's are really lovely receivers, if a bit dated in their software nowadays. Until I got my dreambox nothing else that I tried came close to the way the Echo operated.
__________________ | |||
| | #29 | |||
I set this up yesterday and presumed that it had worked until I spent most of today trying to find something on LNB2, but got nothing. Next, I plugged the working 5W LNB into LNB2 connector on the switch and changed the entries in the Echostar. I get nothing from LNB2 ![]() The switch I have has written on it: Manufacturer: Velleman Model number: ANTSWT2 Frequency range: 900-2400Mhz Insertion Loss: 3dB Power Passing: 500mA max 4 x DisEq switch Compatible with DISC qC 2.0 The companies URL for this is here: http://www.velleman.be/ot/en/product/view/?id=364984 Will this work with the Echostar? | |||
| | #30 | |||
My System: Sky UK family pack. FTA analogue & digital satellite from 5 fixed dishes (4.6E/5E/13E/16E/19E/23E/28E) Pace MSS100, Echostar IP3000VA (with dragon cam), Coship CDVB 2300A, Fortecstar Lifetime Ultra, Technomate TM-1000D, Dreambox 7020S, 2250kb ![]() The last noble sat warrior to fly the olden flag of Analogue | It should do yes.
| | #31 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The spec says that it works with receivers using DiseqC 2.0, so may not work with the Echostar, although most switches tend to be backward compatible.
| | #32 | ||
My System: echostar ad3000ipva and LIDL SL65 on a Wavefrontier t55. Long live analogue sparkles. | After a little bit of fiddeling (errors on my behalf) I have 5W working on LNB2 from the switch. My LNB attached to LNB1 on the switch displays nowt, which makes sence because its not pointing in the right place (as far as I can tell). Cheers all. | ||
