echostar ad3000IPVA and french analouge channels on 5w - sound problem
Information exchange on analogue satellite systems
Old 08-12-2007   #1
qwerty14's Avatar
My System: echostar ad3000ipva and LIDL SL65 on a Wavefrontier t55. Long live analogue sparkles.
Question echostar ad3000IPVA and french analouge channels on 5w - sound problem
Hi all,
Some questions below about my Echostar
1) The default channel scan on 5W gave me a few analouge channels. The picture & sound is perfect.
However, because some were missing I did a blind scan (advanced installation -> autoscan) and the rest of the channels (analouge & digital) were found. The picture is still perfect, except the audio setting is incorrect for the analouge channels. All I hear is white noise and some of the correct sound, sometimes, faintly in the background.
I have looked though the manual and been through all the menu options and have found nothing to change the audio carrier.
Has anyone seen this afore?
Many thanks, qwery!
2) I have a switch connected with : LNB1 5w, LNB2 19.2e.
I set satellite 5w to LNB1, but I cannot see how to do this for 19.2e on LNB2. Nothing obvious in the manual.
3) The s/w revision is ESVCIAP100. Is this the latest?
qwerty14 is offline   Reply With Quote
Old 08-12-2007   #2
rolfw's Avatar
Real name: Rolf
Can you not change the sound carrier using the Audio button on analogue channels?
Rolf
Old 08-12-2007   #3
qwerty14's Avatar
Yes, this is what I would like to do, but I cannot find the magic button Would you know?
PS. I was wrong about the audio being ok on digital. I was watching Canel+ in clear (which has just reencryted itself
Old 08-12-2007   #4
rolfw's Avatar
Real name: Rolf
There should be a button on the remote to select audio, certainly for digital channels.
Rolf
Old 08-12-2007   #5
qwerty14's Avatar
There is at the bottom of the remote, but this does not do anything. Perhaps, it is only for digital. I only have a working 5w feed so cannot check digital (at least the unit does not find anything digital from 5w. Only analouge channels. Perhaps, there are only analouge on 5w?)
Anyway. It don't work
Old 08-12-2007   #6
Site administrator
Analoguesat's Avatar
Most of the 5W analogue channels have the audio on 5.80MHz. Theres an option to change it in there somewhere, although its been a long time since I had to do it on my 3000.
Analogue forever!
Old 08-12-2007   #7
Site administrator
Theres a few digital channels on there as well
http://www.flysat.com/abird3.php
Analogue forever!
Old 08-12-2007   #8
qwerty14's Avatar
weird. wonder why the receiver does not find these either?
Have you got an echostar 3000 and if so, what is the best way for searching for all the analouge and digital channels there?
I have run (normal FTA scan and then auto-scan). In both cases it only received the analouge channels and the latter scan messed up all of the audio ...
Old 08-12-2007   #9
rolfw's Avatar
Real name: Rolf
If your receiver hasn't been used for a while, you will have to add the new transponders, as they probably aren't listed on it.
Rolf
Old 08-12-2007   #10
qwerty14's Avatar
found it!
menu: 6 6 1 : press the yellow button and the analouge audio settings are displayed.
now I have to find out what these are:
selections are comprehesive:
separete left and right frequencies : (current 7.04Mhz)
bandwidth (current 130khz)
deamphasis (adaptive)
Old 08-12-2007   #11
Site administrator
Yup - the last channel /tp lists for the 3000 are way out of date - the last update for them was about 3 years ago.
Analogue forever!
Old 08-12-2007   #12
Site administrator
Spend an hour updating all the frequencies for the satellite(s) you are interested in, then run the channel scan.
Analogue forever!
Old 08-12-2007   #13
qwerty14's Avatar
Smile
1) Please could you tell me exactly what you mean when you say: spend an hour updating all the frequencies? What is the best procedure to update and then scan for both digital and analouge channels?
2) How would I assign 19.2e to LNB2 on my switch?
(I am very new to all this and this is the first dish and receiver I have had since Sky analouge in 1997! )
3) Thank-you.
Old 08-12-2007   #14
Site administrator
From memory (I dont have my 3000 connected up at the moment) frequency additions are in the transponder edit menu (menu 6 6 1 I think)
You also have to change the disecq switch setting in TWO menu's - not a clever bit of design there from Echostar. Cant remember where they are - as I said earlier its been a while since I used it.
Analogue forever!
Old 08-12-2007   #15
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
For two LNB's -
MENU-6-4
LNB - Type 1
Universal
Diseqc 1-4
Diseqc Port 1
KU/C Disable
Store
Now up to LNB again:
LNB - Type 2
Universal
Diseqc 1-4
Diseqc Port 2
KU/C Disable
Store
Back to MENU-6-1
Satellite - Atlantic Bird 5W
Type 1
Store
Satellite - Astra 19E
Type 2
Store
You may need to reverse the Astra/5W settings depending what port they are configured to.
Llew is offline   Reply With Quote
Old 09-12-2007   #16
qwerty14's Avatar
Perfect. Thank-you for the instructions.
Old 09-12-2007   #17
Site administrator
Cheers Llew. I must get my Echostar 3000 connected up again!
Analogue forever!
Old 09-12-2007   #18
Llew's Avatar
Mine's always in service AS - to drive the dish!
I've got a spare too for emergencies - power supply in the old box is getting a bit tired
Old 09-12-2007   #19
qwerty14's Avatar
I tried to add new TPs into the box, but, of course, its not as obvious as I thought.
6-6-1 which says that one can add a TP or satellite, but I could not see how to do this. I could scroll down to 4: TP Frequency, but there was no "Add new TP". Can I simply enter the new TP number and H or V and press OK, or will this delete the TP entry that was previously there?
The TPs I would like to have are:
11064 H Canel Algerie
11512 V TV8 Mont Blanc
11456 V TF1 in DVB
11591 V French Television, and some other French channels in DVB
12711 H ABS-CBN (I think its a news channel?)
12615 H T2 (Tapesh that I think is in English...)
/edit:
I tried entering Menu 5-3 Bluebutton, but this sent me back to the Menu 6 6 1 page above
Old 09-12-2007   #20
Llew's Avatar
querty14, seems like you're trying to add digital channels in the analogue menu.
Switch to digital (green button) input your TP/polarisation/symbol rate and press OK twice then blue button (scan).
Old 09-12-2007   #21
qwerty14's Avatar
Question
I should have gone with my instincts on this one...
I thought, but was not 100% certain, that entering new TPs would delete the current ones, and this is exactly what happened. The new entry removed channel TMC (Tele Monte Carlo). This was on 11456 V.
I am confused about what a TP means.
I thought that it was a frequency (or block of frequencies centred on a frequency) that held several channels. However, the Echostar unit assigns a TP to an individual channel, which is why TMC has disappeared. The receiver had 11456 V assigned to channel 1, (which displayed TMC). I changed this entry for channel 1 to TP 11512 V, and TMC was gone. The message was "no signal".
I appreciate that this thread has moved a little away from pure analouge discussion, but I would be grateful if you would bear with me. If this place in inappropriate then I can start another one elsewhere.
/edit: HI, Llew - I have just read your reply whilst editing. I did not know there was a difference between the analouge & digital TPs.
Old 09-12-2007   #22
qwerty14's Avatar
ahah.
I have found the different buttons for analouge and digi.
As you noted, the menu asks for :
TP
Polorisation
symbol rate
FEC
I found the TP and polorisation on lyngsat but could not see the symbol rate nor FEC, but I think these are really listed as :
SR-FEC
SID-VPID
If I am correct then:
TV 8 Mont Blanc SR: 203 FEC: 321 Audio: 322 F
I could not see a matching entry for SID-VPID, but since there is no entry on the echostar (that I could see) then I won't worry about it.
Old 09-12-2007   #23
qwerty14's Avatar
I worked out the correct settings from flysat. easier to read:
SR 29947
FEC 7/8
TP 11512 V
However, the digital channel setting on the Echostar only lets me scroll through the current TPs, but I cannot see a way to enter a new one. Which menu is this on?
Old 09-12-2007   #24
Llew's Avatar
Yes, you must use the correct menu for each system. This swaps the signal inputs to the appropriate tuner.
You shouldn't lose TMC - I've just added a couple of extra TP's to mine on that bird, TMC remains intact. Maybe your channel data is full in your box; in which case just delete a few unwanted ones on any satellite.
Old 09-12-2007   #25
Llew's Avatar
SR 29947
FEC 7/8
TP 11512 V
6-6-1 (advanced installation)
ad3000ipva, analouge, channels, echostar, french, problem, sound
