astra 19 germany help
Thread Tools Display Modes
Old 08-08-2008   #1
My System: no dish yet. st2 satelitte meter (rover)
Hi all
Just relocated and old working dish pointing at astra.
What readings should i be getting for the best possible signal. I have a ST2 meter. I have never aligned a dish with analouge signal.
There are two cables 1st 950+ 2nd 1250? feeding to a spliter.
Just finished reading the manual and i will try the sat finder and go from there.
Sorry for my lack of knowledge on this.
Any help appreciated
tychi99 is offline   Reply With Quote
Old 08-08-2008   #2
Information Exec
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus V2, Thomson DSI6210 Sky+160, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
Welcome to the forum,
It's the same as the ST-4 but without then TFT screen.
This meter will show a PAL signal trace along with the DVB-S multiplexes.
Select Horizontal Polarisation and Low Band (H/Low) (18V / No 22Khz Tone), switch to spectrum trace mode.
Find the rough angles from dishpointer.com and align the dish until you see the following:
First Analogue peak on 10.714H followed after by two DVB-S transponders 10.744H and 10.773H and then another PAL transponder 10.803H
Hope this helps.
SatMan
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
The Following User Says Thank You to satelliteman For This Useful Post:
tychi99 (09-08-2008)
Old 08-08-2008   #3
Information Exec
65 - 75dBuV
CNR / Carrier to Noise 15dB
__________________
Forum Jump
